EEVblog® Electronics Community Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
FDA approved electronics
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: FDA approved electronics (Read 2480 times)
vicvicvar
Newbie
Country:
on:
March 17, 2023, 12:35:11 am »
Hi all!
I have a project that will be measuring the humidity and temperature of a raw sugar containers of 1.5 Ton. The sensor is a SHTC3 and will not be in direct contact with the sugar but will be in the surroundings inside an FDA approved case with oppening to measure the humidity and temperature.
My question is, how can I prepare the PCBA so it can comply with FDA standards? Is there a conformal coating that I can apply to the PCB that is FDA approved?
All comments/ideas are welcomed. Thanks.
Logged
jonpaul
Super Contributor
Country:
Analog, magnetics, Pwr high voltage, Audio, Cinema
Re: FDA approved electronics
Reply #1 on:
March 17, 2023, 10:28:59 pm »
unless the device is to remain in the container and be shipped into the USA, perhaps no requirement.
Conformal coating is for humidity and fungus protection but contains volatile petrochemical solvents.
Contact à spécialiste in GMP, good Manufacturers Practice.
Jon
Logged
The Internet Dinosaur..
passionate about analog electronics since 1950s
SiliconWizard
Super Contributor
Country:
Reply #2 on:
March 17, 2023, 10:40:28 pm »
If your device is in direct contact with food, there is no way around complying with any regulation it will be subjected to, and not just in the USA.
It's also common sense, not just a legal matter. Do you want to expose food to contaminants?
Logged
jonpaul
Super Contributor
Country:
Reply #3 on:
March 18, 2023, 01:17:51 am »
I hope that the OP knows that Omega Engineering and Fischer Scientific among others make temp, humidity and sucrose concentrate meters,and,Sensors,that are,rated,for pharmaceutical and food manufacturer use.
Jon
Logged
Marco
Super Contributor
Country:
Reply #4 on:
March 18, 2023, 01:31:24 am »
Quote from: vicvicvar on March 17, 2023, 12:35:11 am
Even when the operators screw up? Which they absolutely will.
Not that I worry what that tiny sensor will do to 1.5 ton of sugar, more the other way around. More used to see sensors in nice solid chunks of stainless steel in threaded holes.
Last Edit: March 18, 2023, 01:33:53 am by Marco
Logged
tooki
ejeffrey
Super Contributor
Country:
Reply #5 on:
March 18, 2023, 02:39:07 am »
Definitely you should check with an actual expert. There are a lot of products specifically approved for indirect food contact. I'm more familiar with stuff like paint, lubricants, and glue but there must be standards for electronics. You probably also have to worry about other chemicals used in manufacturing such as flux and flux remover.
Another aspect you might need to consider is whether your product needs to be subject to any high temperature cleaning or chemical sanitation process. If the user is going to spray phosphoric acid on your electronics you probably want to plan for that.
Logged
sparkydog
Regular Contributor
Country:
Reply #6 on:
March 18, 2023, 03:05:16 am »
Don't mess around where liability is concerned. Don't ask a random internet forum how to CYA.
It's one thing if you're doing a personal project where the only person that could sue you is yourself (or
maybe
a handful of friends and/or family). Since I doubt you're mucking about with 1.5 tons of sugar for a personal project... consult an expert. An expert is a
lot
cheaper than a lawsuit. If you can't afford an expert, you have no business trying to hot dog a device on your own.
Also, as noted, there is probably an off-the-shelf part that will do what you need.
Logged
tooki
kermitfrog
Contributor
Country:
Reply #7 on:
March 19, 2023, 04:46:13 am »
Do you have to use "food grade" components ? LOL
Logged
Terry Bites
Super Contributor
Country:
Recovering Electrical Engineer
Reply #8 on:
March 20, 2023, 07:48:20 pm »
There's no definitive chemical answer. It probably won't matter what coating you use because they all have evil combustion products.
I'd be thinking about a hermetic container for capturing the exploding pcb fragments and the magic silicone or epoxy smoke.
Minimise the exposed electronics inside the main container and put most of that in the hermetic box. A one pcb solution can make life very difficult.
Spend time writing your way out of the risk of litigation. (I have spent many an hour).
Show that you took reasonable steps to minimise leakage of dangerous contaminants and shrapnel.
File and forget until you get to court.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog® Main Site
EEVblog® on Youtube
EEVblog® on Twitter
EEVblog® on Facebook
EEVblog® on Odysee
