You are right, I actually haven't had any need to test such high amplitude current pulses at such bandwidth, even after I built my load project
, except for the time when I wanted to test the specs of a current probe I bought. These days when I test power supplies, I just use my Siglent SDL1030x-e which can do 2.5A/us, which is plenty.
I am sure my DIY load can produce cleaner and faster pulse loads, and I can have whatever current load profiles my arb gen can generate. But at the end of the day, good enough is good enough, and the user experience of a polished piece of equipment is much better than my hacked together load. The final 20% of work in a project takes 80% of the effort, and my interest in the project was diverted elsewhere.
One thing to note about the effective bandwidth of a dynamic DC load is, the rise time increases and effective bandwidth decreases with a smaller amplitude pulse, and that's the reason the bandwidth tests were done at the maximum current amplitude I was comfortable with testing. In this respect, the professional load's programmable slew rate setting (independant from the current amplitude) is much more useful and more predictable than saying e.g. my load and do 1us rise time at 20A, but who knows how fast / slow it is at 2A.
I did my dynamic load project mostly as a skill building exercise, (and for the ego boost of one-upping Jim Williams' design
