UPDNow, program capabilities have been extended - it computes section component parameters and provides a resulting Bode plot, including Monte Carlo analysis.
Access via the same link:
Filter SynthesizerThis demo has limited capabilities and covers only the lowpass filter type and VCVS (Sallen-Key) topologies.
Note that 1st-order sections are still not added, so the final realization is possible only for even-order filters, or if an absorbed 3rd-order section is used for odd orders.
How to use.
Left sidebar (expandable) - filter input parameters.
Tabs:
📊 Response Plots - bode plot of ideal response, according to synthesized transfer function;
🔢 Roots & Transfer Function - pole-zero map, transfer function formulas (including LaTeX string);
🧱 Biquad Pairing & Cascading - here pole paired with zeros (if exists), also manual interactive re-pairing is possible;
⚙️ Topology - real physics begins here, choosing section topology (now VCVS available only), solving, picking appropriate solution from table;
📉 Resulting Response & Schematic - tolerances definition and resulting bode plot, including Monte-Carlo analysis.
