OK, putting the finishing touches on this. With one minor exception, all of the electrical/electronic work AND physical fabrication work is DONE for what I'm calling "Phase 1". There will be as subsequent "Phase 1.1" or something like that, and perhaps a "Phase 2", but this phase yields a usable tool, which was the goal.
The one remaining work item, besides tuning the software, is to add a heat-sink on my LM7805 voltage regulator. It's running a little bit warmer than I'd prefer. I thought I could get away with it as is, but between the Arduino and the LCD, it pushes it just hard enough to where it gets a bit warm.
Anyway, some pics of the progress to date.
Finally cleaning up the mounting of the boards, adding spacers to keep the boards from flexing, etc.
I built a couple of long banana-to-banana jumper cables out of unused extension cords. This way the controller can sit on the bench while I tinker with it, but actually run the oven "live" for testing.
And wired up those banana plug connectors on the inside.
And that's pretty much it. The whole thing, all packaged up and ready to use (modulo some software tweaks).
Powered up and displaying the default greeting on the LCD.
The view from behind.
Anyway, that's basically it. I'll add that heatsink, finish merging the bits of software that I had originally developed in different projects, reflash the Arduino, and I'll have a usable reflow oven.
Things for "Phase 1.1" - adding the piezo buzzer that will buzz when the profile run is finished. I'm just not motivated to work on that right now. I need a break from this for a little while.
Things for "Phase 2" - finally implement the automatic door opener, and
maybe design a real PCB for the electronics, mill it out, and solder it **in this very oven** and then rebuild everything in what will hopefully be a much cleaner / more elegant fashion. The circuit board layout / design here was really ad-hoc and kinda "making it up as I go" and could be way improved. It works, but some of the choices I made wound up making things difficult in the final assembly phase, and don't lend themselves to making this easy to maintain / repair, etc.
"Phase 2" might also include heat-press-fitting threaded inserts where the board mounting screws go, and not have that stuff sticking through with those nuts on the outside. If I do, then I could turn around and use a little dab of epoxy / bondo / J.B. Weld / etc. to cover over the holes so everything looks nice and smooth from the outside.
Edit: also if anyone is wondering, no, I don't intend to leave the control box sitting on top of the oven when it's in use.
That's the whole reason for the long jumpers connecting the box to the oven, so I can set it off to the side while the oven is actually running. The one thing I should probably also consider, is using a longer thermocouple wire. I think the kit I ordered included two, the one seen here, and one much longer one. That is, if memory serves correctly. If so, I should probably swap it out, as right now that thermocouple is the limiting factor in how close the control box has to be to the actual oven.
