Here's me trying to get a little experience with KiCad & the whole EDA thing. This is a little R/2R network to allow my power logger to log three binary channels on it's 10V analog channel. Feel free to poke it apart-you won't hurt my feelings.
The power source is nominal 24VAC, actual could be as high as a strong 27 volts RMS (60Hz), a bog-standard (in the US) 24V xfrmr. The regulator is an amazingly-high-input-voltage 3 term linear regulator I found after I realized that a 7810 wouldn't cut it with the peak input voltage. Only 3mA output current, but the impedance of the analog channel is appx 225.6k per the manual, that'll be plenty? The cap values were taken straight from the data sheet.
A handful of things I already know about: I just grabbed footprints for the caps, resistors, & diodes. I'm pretty sure they're the wrong size. I couldn't find a polyfuse small enough for the output, they don't make one that'll hold 3mA, trip around 30mA (Ipeak from the data sheet)? The board layout is atrocious-I just threw the parts down. The first version I laid out pretty much like the schematic, but then I wanted to put some tracks on the bottom side. The combined board PDF was made by printing an XPS & converted to PDF via a tool, I believe it left a few artifacts, missing pads & barely connected tracks.
