Hi Jones12,
1) AVCC is not powered. Check user manual.
2) Add a capacitor on the RESET pin, --> check the user manual for power on reset and it helps for EMC immunity.
3) Just in case, add diode in the power supply plug. If the current is to high, place the diode in parallel and add a fuse.
4) C4/C5 should have the same value. If X1's CL=12.5pF, keep 22p for both.
Theo
