Author Topic: flame triode  (Read 1756 times)
Offline coppercone2Topic starter
  • √Y√... 📎
flame triode
« on: March 27, 2023, 05:59:52 am »
Hallowed are the Ori.
I did not see a thread about this thing, and I find it fascinating, including the idea of using magnetic fields on the plasma to modify the parameters of the flame
https://hackaday.com/2016/05/26/flame-triodes-dont-need-any-vacuum/
Offline gnuarm
  • Country: pr
Re: flame triode
« Reply #1 on: March 27, 2023, 05:23:27 pm »
I never tried a flame triode, but I did build a flame speaker once.  It used a propane torch and carbon electrodes.  Back then I had a tube amp with a transformer output.  It barely made sound when on the appropriate tap on the transformer.  The other taps would not produce sound.
I think we're going to need a bigger amp!
Rick C.  --  Puerto Rico is not a country... It's part of the USA
  - Get 1,000 miles of free Supercharging
  - Tesla referral code - https://ts.la/richard11209
Online Gyro
Re: flame triode
« Reply #2 on: March 27, 2023, 07:10:19 pm »
You're going to need a horn at least. Trying to drive the air with an effectively 'massless' diaphram is going to be hard. Plasma tweeters work by thermally modulating (expanding) the air. With a propane torch and electrode, you're effectively just moving a constant temperature 'zero mass' flame around a bit.
Best Regards, Chris
