Author Topic: Flex PCBs  (Read 8793 times)
Alex
  • Guest
Flex PCBs
« on: January 03, 2011, 07:57:13 pm »
Hi all,
I am putting together a project that requires a flexible PCB. I am planning to use polyimide film coated with copper, the standard way of doing it.
I was wondering if you are aware of any supplier or shop that stocks this material (or similar) and that I can access from the UK. The exact dimensions and specifications are not critical, but I only need an A4-sized sheet or so.
If you have made a flexible PCB using a different material then please, do share.
Thanks
« Last Edit: January 03, 2011, 10:21:04 pm by Alex »
Offline mikeselectricstuff
    • Mike's Electric Stuff
Re: Flex PCBs
« Reply #1 on: January 03, 2011, 10:53:08 pm »
Farnell sell this photoresist flex PCB
Day Job: Mostly LEDs
Alex
  • Guest
Re: Flex PCBs
« Reply #2 on: January 03, 2011, 10:56:31 pm »
Many thanks Mike!
Re: Flex PCBs
« Reply #3 on: January 03, 2011, 11:06:13 pm »
Better double check - looking again it appears this isn't presensitised - the picture shows a peel-off film, but the data refers to it as 'raw'.
I have some stuff I bought a long while ago, which to add to the confusion is photoresist but does not have a peel-off film.
Alex
  • Guest
Re: Flex PCBs
« Reply #4 on: January 03, 2011, 11:08:36 pm »
It doesnt matter, I can other coat it myself or use e.g. the toner transfer method.
Offline TheDirty
Re: Flex PCBs
« Reply #5 on: January 04, 2011, 02:20:42 am »
What do you mean by flexible?
You can use this copper clad, if you just want to bend the board around something.
http://www.goldmine-elec-products.com/prodinfo.asp?number=G17455
If you want the PCB to be able to flex multiple times and not break, like a commercial FPC, then I have no idea how you would approach that hobby wise.
Mark Higgins
Alex
  • Guest
Re: Flex PCBs
« Reply #6 on: January 04, 2011, 09:43:33 am »
By flexible I mean a circuit board that can bend to a radius of 3cm about 100 times during its lifetime without being damaged.
Thats an interesting approach, a bit worried that it would be fragile.
Flex boards are normally made with polyimide film commercially.
Offline JohnS_AZ
    • About.me
Re: Flex PCBs
« Reply #7 on: January 05, 2011, 12:30:22 am »
I don't know how fancy you need to be, but in the past I've built prototypes using the flex material that connects the print head to it's drivers from trashed dot matrix printers.
I'm either at my bench, here, or on PokerStars.
Alex
  • Guest
Re: Flex PCBs
« Reply #8 on: January 05, 2011, 12:39:29 am »
How did you make your own circuit though? That flex pcb is just the equivalent of a flat ribbon cable. I am looking to etch a custom pcb design.
The CIF flex protoboard material that mike suggested and the Dupornt protoboard material that I also found are the equiavent of a 'blank' copper clad board.
Re: Flex PCBs
« Reply #9 on: January 05, 2011, 10:34:41 am »
I just rememembered where  I got some photoresist flex from : Mega, who  incidentally are good for pretty much any PCB-making supplies.
Alex
  • Guest
Re: Flex PCBs
« Reply #10 on: January 05, 2011, 10:52:02 am »
Thanks Mike, a similar price to the product on Farnell.
Offline Zero999
  • 0999
Re: Flex PCBs
« Reply #11 on: January 05, 2011, 06:53:04 pm »
Alex
  • Guest
Re: Flex PCBs
« Reply #12 on: January 05, 2011, 08:15:47 pm »
The Mega and Farnell SS boards are of a similar price. I have got a SS sheet from Farnell to try it out.
Re: Flex PCBs
« Reply #13 on: January 06, 2011, 09:27:23 am »
Can you confirm that the Farnell's stuff is not photoresist coated?
The Mega stuff definitely is.
Offline Zero999
  • 0999
Re: Flex PCBs
« Reply #14 on: January 06, 2011, 05:48:47 pm »
Have you tried Farnell technical support?
Re: Flex PCBs
« Reply #15 on: January 06, 2011, 10:57:43 pm »
Excuse my scepticism based  on the sometimes patchy  info on teh Farnell website but I would sooner trust info from someone who actually has it in their hand....
Alex
  • Guest
Re: Flex PCBs
« Reply #16 on: January 07, 2011, 02:07:24 am »
It turns out the CIF product on Farnell is without photoresistive coating, just a peelable cover on the copper.
The product on Mega is 3 times bigger than the one on Farnell for the same price, and it has photoresistive coating which can be removed if one is to use the toner or solid ink processes.
