Note that putting more transistors in the loop invites the same problems a TL431 does: higher dynamic impedance, and stability.
I don't like the un-degenerated emitter in cascade: the gain varies too much with operating point. A little degeneration puts a ceiling on that, and then it can be designed to guarantee stability.
Speaking of dynamics, I suppose a cap across the top divider (P1 + R1 in the last one above) would be the most effective, and maybe an R+C there would be necessary to stabilize a 2 or 3 stage one, in some conditions.
The tempco isn't easy to cancel (short of building a whole-ass bandgap circuit, or the matching zener), but it can be tweaked with an NTC thermistor partially in parallel with R2. Namely, an NTC plus some normal (non-sensitive) resistance, and that pair in parallel with another (non-sensitive) resistance, makes up the whole equivalent of R2, and this can be tuned to give pretty reasonable behavior (like <10% error from 0-85°C). Or at relatively high ratios, I think a PTC (Ni or Pt RTD?) is about right, but it has to be the entirety of P1+R1? So your adjustable range has to be done at R2.
Adjusting R2 is generally safer anyway, as long as it's by small increment still -- in general, only use what adjustment range, or V/I operating range, or etc. -- you need. Design not just the desired operating point but its extremes as well. For the general case, that means making, like, amplifier stage input and output ranges match each other, so that they tend to saturate about the same point. Anyway for this, adjusting R2 means, if the wiper goes loose (as they inevitably do), it defaults to a lower voltage -- in an amplifier Vbe mult, this increases distortion instead of causing runaway bias.
