Author Topic: forward leakage of a diode ...  (Read 14321 times)
Offline Leo Bodnar
Re: forward leakage of a diode ...
« Reply #25 on: August 25, 2017, 07:44:20 am »
Vincent, these curves are 25 years old in case you are using them as selection tables or design references and they were taken from just one random product sample.  Super-bright LEDs were not even invented back then.  I think Bob's intention was not to compile a selection table but to illustrate his thinking process - I was hoping you'd get the book and read it.
This is amazing thread.  As a free bonus, there is some discussion about diodes here.
Leo
P.S. Could we please stop using "leakage" in relation to normal forward conduction?  It confuses the hell out of me and probably a lot of others.
« Last Edit: August 25, 2017, 07:50:10 am by Leo Bodnar »
Online Kleinstein
« Reply #26 on: August 25, 2017, 07:52:55 am »
In the very low current range one might have to check / measure the parts used. Except for expensive special low leakage parts, they diodes are not tested for leakage down to the low pA range, as this is expensive (because it takes time).
LEDs might be a good option - though you need to check. The typical current will be low, but one can not be sure. If the high forward voltage is not a problem, especially blue ones would be worth a try.
Extrapolating the diode equation / curve down to very low voltages can be tricky. Quite often there are other contributions than the idea diode current you see at higher currents. Quite often there is at least a contribution with a higher (e.g. 2 ) ideality factor at low currents, that is just not relevant at the more normal currents.
Online Alex Nikitin
  • Femtoampnut and Tapehead.
    • A.N.T. Audio
« Reply #27 on: August 25, 2017, 08:01:11 am »
Here are the graphs from my measurements for the  1N4148 and BAV199 forward (50mV -500mV) and reverse (50mV -100V) currents at about 26C ambient.
Cheers
Alex
* I've measured a number of samples of each diode, as well as BAV199 diodes from five different manufacturers. The comparative curves are average for the 1N4148 and for the worst make of the BAV199. The best makes of the BAV199 have almost ten times lower forward and reverse currents.
« Last Edit: August 25, 2017, 08:17:04 am by Alex Nikitin »
Offline capt bullshot
« Reply #28 on: August 25, 2017, 08:10:58 am »
This is an interesting thread ...
IMO using one or more diodes in forward direction to achieve the OPAMP protection isn't the right way.
Most opamp inputs are well protected if one limits the maximum input current to some value in the 5mA ballpark. If you limit the voltage across your sensor input to say +/- 7V using back to back connected transistor BE junctions as zeners, one can achieve OPAMP protection using a simple 4k7 resistor. You might need a zener across the OPAMPs supply pins to catch that injected current, depending on your power supply switching scheme.
I don't know the exact figures of the BE zener leakage, it is believed to be very low. So I'd just consider a architecture change of the protection network.
Offline tszaboo
« Reply #29 on: August 25, 2017, 10:25:29 am »
First of all, the correct term, you are looking for is "subthreshold" leakage. It help a lot with the google-fu.
And yes, diodes are not very well defined in this region. But transistors are. You can use 2 transistors of your choice, by connecting the base to the collector, and look up the Collector Cutoff Current. That will be almost your value. It is 0.2nA-15nA for a BC546. Temperature dependent a lot of course.
The following users thanked this post: Leo Bodnar
Offline Leo Bodnar
« Reply #30 on: August 25, 2017, 10:38:45 am »
Score!
http://www.google.co.uk/search?q=%22diode+subthreshold+leakage%22
Offline oldway
« Reply #31 on: August 25, 2017, 11:07:25 am »
BAV25 is the diode you are looking for.....it has a leakage of 0.1pA at 100 mV forward voltage.
Online Alex Nikitin
    • A.N.T. Audio
« Reply #32 on: August 25, 2017, 11:23:08 am »
Could you provide a link to a data sheet on this diode (Google search draws blank)?
Cheers
Alex
Offline AndyC_772
« Reply #33 on: August 25, 2017, 11:37:07 am »
I'm struggling to see the physical mechanism by which a component might be damaged, with a 100K resistor in series with it.
IC damage is caused by local heating, when a non-trivial current flows through somewhere it shouldn't. How much current are you expecting to be able to draw through that 100K resistor under fault conditions?
Online Alex Nikitin
    • A.N.T. Audio
« Reply #34 on: August 25, 2017, 11:53:40 am »
anyway. this is dancing around the subject. all i want to find is a diode that does not leak in forward mode.
BAV199
Cheers
Alex
Offline oldway
« Reply #35 on: August 25, 2017, 12:51:34 pm »
Cheers
Alex
Online Alex Nikitin
    • A.N.T. Audio
« Reply #36 on: August 25, 2017, 01:12:59 pm »
Cheers
Alex
So it is BAV45 (obsolete from Philips and the replacement from Central Semi has nothing in the data sheet on the forward current values at these levels). About the same performance as the BAV199, which is easily available for a fraction of the price. There are more low leakage diodes available, including FJH1100 from Fairchild (very expensive, photo-sensitive and not as good as the BAV199), PAD series from Vishay (also expensive and not easily available, no specs on the forward current v voltage).
Cheers
Alex
Online Alex Nikitin
    • A.N.T. Audio
« Reply #37 on: August 25, 2017, 01:31:23 pm »
Here is a possible solution for the topic starter.  If it is possible to sacrifice a couple of uA to forward bias two diodes, the summary leakage through D1 and D2 diodes in this circuit at 0 to 1V on R2 would be under 0.1pA at 25C (typical figure).
Cheers
Alex
Offline oldway
« Reply #38 on: August 25, 2017, 01:45:13 pm »
Also the diode FDH300 (very low forward leakage)
http://www.onsemi.com/PowerSolutions/product.do?id=FDH300
In SOT-23, MMBD1501/A
« Last Edit: August 25, 2017, 02:03:41 pm by oldway »
Offline David Hess
  • DavidH
« Reply #39 on: August 25, 2017, 02:14:32 pm »
The high currents involved can also cause electromigration which is both current and temperature dependent.  CMOS gate structures may suffer from punchthrough of their gate oxide.  The parasitic thyristor in CMOS junction isolated processes may be activated crowbaring the supply if powered.  Base-emitter breakdown damages bipolar transistors when the hot carriers cause dislocations lowering hfe by increasing recombination; this is why bipolar precision operational amplifiers include back to back input diodes to protect against high differential input voltages if their base-emitter junctions are exposed. (1)
Just a series resistor may not be sufficient if its breakdown voltage is exceeded.  For the same reason, creepage and clearance matter.  In the past they used carbon composition resistors for their good short term overload capability but today one of those inexpensive fusible high voltage film resistors would be suitable if you are paranoid enough and cannot rely on additional shunt protection.  The rise time of an ESD pulse is fast so bypass capacitance matters as well.
Things are worse when you consider that it is the machine ESD model which likely applies instead of the human ESD model.
(1) Many PNP input operational amplifiers avoid this problem but I do not know that they are any more ESD resistant.  NPN input cascode operational amplifiers also avoid it but again, I do not know that they are any more ESD resistant.
Online Alex Nikitin
    • A.N.T. Audio
« Reply #40 on: August 25, 2017, 02:15:08 pm »
Not really in the same class, less than 400mV for 1uA forward current typical. The BAV199 has around 500-550mV at 1uA .
Cheers
Alex
Offline free_electronTopic starter
    • SiliconValleyGarage
« Reply #41 on: August 25, 2017, 04:07:15 pm »
 :palm:  so sorry. sensor output is 1mA .... not 1uA ...
Me : then where does this 1m megaohm requirement come from ?
they: that is input resistance of multimeter so you get no erro ...  (the spelling of erro gives it away right ? )
screw it i'm putting a simple TVs diode across there. and i'm gonna use a 100 ohm sense resistor with an x10 amp.
the only requirement is that the burden voltage of the system should not go above 1.2 volt. as that causes unwanted electromigration in the electrodes.
During normal operation the output is in the order of 50 to 60 microamps. only at full reaction does the sensor deliver 1 mA. but that is not realistic.
something along these lines (image below) will clip enough incoming crap (esd, people with screwdrivers ... ) that it has no impact and protects the input opamp.
Anyway. Interesting puzzle. How to protect a line that has a high impedance ?  Most diodes don't work as they leak to much in the 'subthreshold' zone, and manufacturers don't specify the data for that area. so good luck finding something that works. the transistor as a diode trick would work. That's why keithley uses a matched pair antiparallel as input clamp for their electrometers. ( dave's recent video reminded me of that and i was working on this 1uA pretection thing so one thing lead to another )
And yes , diodes follow that equation but even that is useless information to solve this problem. you don't know half of the parameters used , manufacturers don;t list em. so all you are stuck with is trial and error. which i wanted to avoid in the first place.
One thing learned : when looking for some information that is hard to find : check Bob Pease books FIRST. most likely he's already done it.
The following users thanked this post: Tomorokoshi
