Author Topic: Front Panels  (Read 626 times)
Offline ExcoriatorTopic starter
Front Panels
« on: June 26, 2025, 01:00:50 am »
Hopefully my way of making professional looking front panels will be of interest to others.
Getting sheet aluminium laser cut is a service provided by several Chinese PC manufacturers, but I found a UK Firm - Fractory - was prepred to produce ten off of a panel roughly 70mm by 230mm with a variety of cut outs for switches and BNC connectors for around £70. I imagine you can get smaller quantities for a moderate fee from chinese companies too.
I sent them a design file and received the accurately cut panels. These were unmarked, so I sprayed them a cream colour, and instead of silk screening used a water transfer system. This allowed me to print the markings - labels and titles and logos etc onto the transfer material which I bought online as A4 sheets - using a colour laser printer. The resolution is limited only by that of the printer. I guess you could print colour photographs as a background if you wanted to and get quite acceptable results.
The material is available on the internet and consists of backing card with a thin plastic film carrying the design. I could get two panels printed on an A4 sheet, which I cut to slightly smaller than the panel. These were soaked in water for two or three minutes which releases the film from the backing. I was able to slide the transfer film from the backing sheet onto the panel, and gently stroke it with card to exclude water bubbles from beneath it.
I left them for a day or two to dry (You can also dry it in an oven a 100C) and the result seems to be every bit as durable as silk screening. The film hardens and sticks to the panel. The resolution is better than silk screening. I suppose you could give it a coat of spray on varnish, but I didn't bother. You have to cut the film which covers the holes, but you can do this when its dry with a scalpel quickly enough.
I've used one of the final project - an Audio oscillator with a built in digital frequency meter - myself for about a year and the transfer seems as good as new. Some friends I've made them for have found the same thing so I believe durability is not a problem.
Hopefully, this will help others make professional looking front panels simply and easily and at minimal expense and hassle.
The following users thanked this post: lowimpedance, moffy, neillnz
Online moffy
Re: Front Panels
« Reply #1 on: June 26, 2025, 01:08:34 am »
Thanks for the info, good looking front panels in small quantities at reasonable cost can be quite a challenge.
