Author Topic: FTDI Programming Issues  (Read 1406 times)
Offline physiiiTopic starter
« on: June 28, 2016, 01:49:31 pm »
I am having trouble programming through USB. I can read data from the port fine, problem is, I can not write to the microcontroller unless an external programmer is also attached to TX and RX (see attached pictures). With that attached I can read and write through the USB.
I would like to fix this in the next revision, can someone help me out?
Thank you
physiii
