Yes, the $1.60 is way too much.
Though I ordered samples for these anyway.
From the same seller ordered 50x 2P male + 50x 2P female for around $0.30/unit (a bit more like the cost I am looking for), these ones:
https://www.alibaba.com/product-detail/Edge-Surface-Mount-PCB-2-5mm_1600404699176.htmlThe idea is to go buy and assemble connector quantities of say 10 000 to 100 000 at some point.
Thanks for sharing the link, I am wondering though, how good do these magnets hold in there? Could I be dropping PCBs with these magsafe-style connectors on the floor constantly and not getting magnets loose quite soon? I guess spending on some good glue - required.
And I have similar sentiments about my requirements being quite niche (and maybe impossible to find an economic solution).
Though in theory, this should be at least doable by recessing male contacts and protruding outwards the female ones.
See the image attached.
Well, I could get each contact separately and in assembly place a female + a male side by side.
Though, not sure what the alignment success rate would be coming out of oven
Who knows, maybe an undersized pad + solder wetting forces would do miracles? (Definitely no expert in that.)
Though, another (more significant) issue I am having - this particular seller has not responded about any tape & reel options or consideration to take care of that for large quantities.
