Hi. I would like to create a 1280KHz +/-0.5% clock signal for a project. It just need to be a regular 3.3V CMOS voltage level clock. So far I used a signal generator for it, but I need to make the setup more mobile and production ready. Do you have a good idea about for creating this clock signal?
How adjustable does it need to be. There are i2c Clock generator modules (eg Adafruit) based on Si5351A, that can set any frequency.
A crystal, resonator, or a oscillator are the obvious choices, and an oscillator with divider is also an option.
You can still buy 74HC6323 parts, which give many choices in SO8 /1 /2 /4 /8 allowing 2.56Mhz 5.12Mhz and 10.24Mhz as alternate choices.
Or, you can use a 74HC4060 and 20.48MHz Xtal or Osc source to give /16 at 1.28Mhz
Mouser have 5.12MHz ceramic resonators that have some pull range, needing a /4
Digikey and Mouser have a lot of 20.48MHz crystals that will work with a 74HC4060
