Author Topic: Getting custom cable made  (Read 4829 times)
Online SimonTopic starter
  • Global Moderator
    • Simon's Electronics
« on: February 09, 2016, 06:21:10 pm »
We are looking to get some custom cable made. I don't think this is available off-the-shelf as we require a temperature rating of 150 degrees or more. Are any companies in the UK anyone can recommend for this purpose?
Offline Christopher
Re: Getting custom cable made
« Reply #1 on: February 09, 2016, 06:26:16 pm »
  • Global Moderator
« Reply #2 on: February 09, 2016, 06:28:28 pm »
I use type 55 by raychem where possible.
https://www.rbracing-rsr.com/downloads/wiring_pdfs/spec55wire.pdf
We tend to use type 44 Raychem cable which is good for 150 degrees but yes I would like to use a wire of this grade or of the 55 type to create cables that are 3 sets of twisted pairs so not something I'm likely to get off the shelf with this temperature rating.
Offline Neilm
« Reply #3 on: February 09, 2016, 06:36:21 pm »
I know at work we have used a company called K Lacy for some of our cables. The ones we get are nothing special, but I did approach them for a high temperature cable. They couldn't supply the connector we needed, so we didn't use them and ended up going to a Swedish company instead.
Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. - Albert Einstein
Tesla referral code https://ts.la/neil53539
  • Global Moderator
« Reply #4 on: February 09, 2016, 06:39:16 pm »
We fit the connectors ourselves I just need the actual wires spinning together into a cable. If I ask our harness supplier he will get the cable made out and that means we are tied to using him as we would have to have a bulk quantity made. The only other supplier I know will go elsewhere and get it done for us so I'm wondering if it's worth just jump in the middle men and being in a position to free issue the cable to any Harness manufacturer we want.
Offline HAL-42b
« Reply #5 on: February 09, 2016, 06:50:05 pm »
Spinning a cable requires a simple manual jig. If you are looking for small quantities spinning it in house may be the way to go.
I was quoted minimum order of 300kg when I tried to do something similar.
Offline Neilm
« Reply #6 on: February 09, 2016, 06:50:26 pm »
I would have thought you would end up spending more storing the cable than you could save.
  • Global Moderator
« Reply #7 on: February 09, 2016, 06:56:45 pm »
The whole cable needs covering in braid and a jacket that is not something that we can do in large volumes and is something that our harness manufacturer will charge a lot of money for so as it's cable that we will use often it worth having a roll of it created but going to a middle man is going to be more costly as they will just sell us the whole real anyway rather than sell it to us by the meter when we wanted. I wouldn't have more than hundred metres in any case.
Offline Christopher
« Reply #8 on: February 09, 2016, 07:33:32 pm »
Speak to TE directly thru Rayfast.. They have quoted me before for twisted pair type 55 and it wasn't that expensive but their twist rate wasn't any good
Spinning up large lengths (more than 10m) is very hard... My limit is 3m and even then it's really tedious!
  • Global Moderator
« Reply #9 on: February 09, 2016, 07:37:19 pm »
Well I have rayfast on the case already. Someone must be able to twist cable in large lengths as they do supply single two core off the shelf. Yes the twist won't be that dense.
Offline PChi
« Reply #10 on: February 09, 2016, 07:58:11 pm »
Offline _Andrew_
« Reply #11 on: February 09, 2016, 08:30:07 pm »
The company I use to use to manufacture custom cables was Nexans. If I remember correctly for custom cable minimum order quantities were in kilometres.
http://www.nexans.com/eservice/Corporate-en/navigate_-10/Global_expert_in_cables_and_cabling_systems.html
Offline rob77
  • Country: sk
« Reply #12 on: February 09, 2016, 08:50:35 pm »
it was the same here and lead times were in months.... (but i'm not in that kind of business for a decade... but i doubt it has changed ;) )
  • Global Moderator
« Reply #13 on: February 09, 2016, 08:51:25 pm »
Yes the lead times will be a problem, I may end up making my own.
Offline IconicPCB
« Reply #14 on: February 09, 2016, 09:20:11 pm »
Have a chat with this mob
http://www.novkabel.com/en/katalozi/Catalogues.html
They are a cable manufacturer and will sell in low volumes (say a hank of wire ).
