Author Topic: golf cart  (Read 10489 times)
Offline House91320Topic starter
golf cart
« on: April 15, 2011, 04:36:32 pm »
Dose any one know what type of motor a golf cart uses.
Offline sacherjj
Re: golf cart
« Reply #1 on: April 15, 2011, 04:49:58 pm »
36-48V  2-8HP electric motors.   Some need controllers up to 400A.  Maybe can provide more info if you ask what you are trying to know.
Not to be too snarky, but you can also try this link.
Re: golf cart
« Reply #2 on: April 15, 2011, 05:01:12 pm »
i have searched googel but it didn't answer my question. What do the 4 leads on the motor do
Offline DaveW
    • WattCircuit
Re: golf cart
« Reply #3 on: April 15, 2011, 05:36:27 pm »
If they've got 4 leads, then it's probably 2 leads for the field windings and 2 wires for the armature. The field windings take the place of the magnet normally used in DC motors. You can run these in parallel or series, but for lower power motors, they're normally shunt wired,
HTH
Offline Zero999
  • 0999
Re: golf cart
« Reply #4 on: April 15, 2011, 06:13:41 pm »
It's becoming more common for electric vehicles to use an AC motor driven with an inverter rather than a DC motor for increased efficiency and reliability but this applies more to cars than small vehicles like golf buggies.
Offline tecman
Re: golf cart
« Reply #5 on: April 15, 2011, 06:28:04 pm »
Brushed DC motors are still the norm on carts.
the reason for bringing all 4 leads out (field and armature) is to be able to reverse the motor.
paul
Offline sacherjj
Re: golf cart
« Reply #6 on: April 15, 2011, 06:55:45 pm »
You also may have leads for an integrated tach sensor.  Though these will be much smaller gauge.
Online firewalker
  • Country: gr
Re: golf cart
« Reply #7 on: April 15, 2011, 07:42:23 pm »
Once I came across a dc motor of a small electric cart with 4 leads. 2 for powering the motor and 2 for an electro-mechanical brake inside the motor.
Offline Zero999
  • 0999
Re: golf cart
« Reply #8 on: April 15, 2011, 07:50:56 pm »
Are you sure the extra leads were for the break? They're more likely to be for the field winding.
Offline sacherjj
Re: golf cart
« Reply #9 on: April 15, 2011, 07:54:52 pm »
I agree.  These can be used as a regen brake with the right controller, but they are still just the normal windings.
Offline DaveW
    • WattCircuit
Re: golf cart
« Reply #10 on: April 15, 2011, 08:38:35 pm »
They are for an electromagnetic brake-this is for smaller motors though, almost all motors used for applications such as mobility scooters have them
Offline Zero999
  • 0999
Re: golf cart
« Reply #11 on: April 15, 2011, 10:42:57 pm »
Care to post a link to such a motor.
Offline DaveW
    • WattCircuit
Re: golf cart
« Reply #12 on: April 16, 2011, 12:35:57 am »
Have too much stuff on my pile to get a picture of mine, but this is an example
http://www.societyofrobots.com/robotforum/index.php?topic=5553.0
There are two plates which are clamped down onto a flange on the motor shaft. When power is applied (typically 24V) the two plates are separated and the motor can spin freely. This means that in the event of a low battery or when a wheelchair/mobility scooter is parked, it won't start rolling down a hill
http://www.brookcrompton.com/pdf-files/2010e_brakes_v1.pdf Page 7
« Last Edit: April 16, 2011, 12:50:44 am by DaveW »
Re: golf cart
« Reply #13 on: April 16, 2011, 12:58:55 am »
the golf cart is an old version with relays for the control, it doesn't seem to be a brake any one have an idea.
Offline DaveW
    • WattCircuit
Re: golf cart
« Reply #14 on: April 16, 2011, 01:02:54 am »
Are you sure they aren't separate armature and field windings?
Re: golf cart
« Reply #15 on: April 16, 2011, 02:58:20 am »
tats what i think it is but i don't know what pin dose what.
Offline DaveW
    • WattCircuit
Re: golf cart
« Reply #16 on: April 16, 2011, 11:32:30 am »
Are all the wires the same gauge? And the best step would be to measure the resistance between all the wires
Offline Zero999
  • 0999
Re: golf cart
« Reply #17 on: April 16, 2011, 11:49:28 am »
I would expect the break to have a higher resistance and the same is probably true for the field winding.
Re: golf cart
« Reply #18 on: April 16, 2011, 02:49:35 pm »
schematic
Online firewalker
  • Country: gr
Re: golf cart
« Reply #20 on: April 17, 2011, 07:07:18 am »
Yes, I took apart the motor. The system looked alike like the one found on large ac asynchronous motors.
Like the one above. The thing is that this one was inside the motor, you couldn't tell right away that it had a brake. E.g this type of brake, on a.c. motors usually, is like an extra part on the motor (see picture bellow).
« Last Edit: April 17, 2011, 07:16:13 am by firewalker »
Offline buffalo960
Re: golf cart
« Reply #21 on: April 17, 2011, 09:21:26 pm »
House,
Can you take a picture of the motor and post it here?
Re: golf cart
« Reply #22 on: April 18, 2011, 10:07:27 pm »
I figured it, out it is power for the rotor and power for the stator.
