Hello,
I have simulated a grid tied inverter by simply having an isolated 400V supply….then having a PWM with a sinusoidally varying duty cycle which switches via a bridge into a Filter to filter out the switching harmonics and leave behind the 50Hz waveform.
Would you say this is a good modus operandi?
Its as in the attached simulation in LTspice
