EDIT: This thread results in two Auxiliary Function Generator input circuits... One, as an additional option, for Jay's Dynamic Electronic Load Design. And, two, another that does not use Jay's Function Generator option. Many, many thanks, to those that participated, in the work. And, of course to Jay, for the original E-Load circuit, itself. The hack would not have come together, without them!I am working toward building Jay Diddy B’s Dual Supply Dynamic Electronic Load. You can find it, here:
https://www.eevblog.com/forum/projects/dynamic-electronic-load-project/. The schematic, for my adaptation, is attached, below.
Note About My Schematic
Jay has told me that the values of my resistors for the Meter Output are incorrect… As is, they, in total, produce 25mV. I am working on getting them changed. (If you know the formula, feel free to calculate the value.)
And, I mislabeled the op amps... I used the quad symbol, of the LT1014, but labeled it as the dual LT1013. Creating a final schematic, for Jay's project, and for my personal preferences, is in the proofing stage. This is how this was just discovered.
Disclaimer: I have posted these questions, within Jay’s thread. They have not been answered. I think, because they add project creep. To avoid that, I think it better, to post them as a separate thread, because this is for my own singular purpose.
A prominent feature, of the design, is an on-board square wave oscillator that can be used to test the slew rate of power supplies. I want this feature, but I have several Function Generators, that have auxiliary outputs. I’m thinking that I would have many more options (a sign wave, in particular, variable frequency, etc.,) if I removed the on-board oscillator and added an input, for a Function Generator. I am an intermediate noob and these design questions are beyond my knowledge base. So, I would appreciate your help.
Adapted from previous post:
If using an independent function generator would add functionality greater than the on-board oscillator, where, and how, should it be injected, in the circuit? Just use the type jack that breaks the circuit? Break Before Make? What issues might there be?
If using an independent function generator is not wise, then I would keep the existing oscillator. If I wanted to add a switch, to bring in, or cut out, the oscillation section, without spinning its adjustment knob, to zero, where, and how, would it go?
Would there be any great advantage to using ten-turn pots? I would think that, for home-lab use, things just aren’t going to need to be so precise. Thoughts?It is most likely that I would be using the function generator that is in my Tenma Universal Test Center 72-1005. The auxiliary output is selectable; 50 Ohm, or 600 Ohm.
Its operation manual and schematic are too big to post. I have placed them in a DropBox, so that you can know exactly what we are working with.
https://www.dropbox.com/h If you have trouble getting them from DropBox, just send me a PM with your email address and I will send the files to you, direct.
I am concerned that some of its functions might damage the Electronic Load circuit… Like the pulse feature… Or, too much input gain. The operation manual explains all of its features.
Thank you, in advance, for your help. In appreciation of your support, I would be glad to post the completed KiCad schematic file, for my version. (I am already set up to release Jay Diddy B's design, on his thread.)
