Author Topic: hacking atx power supply  (Read 2842 times)
Offline justin66Topic starter
« on: March 19, 2016, 07:29:46 pm »
hey guys i would like to figure out a way to hack the atx power supply with a controller sg6105dz. i have tried a few logical ways to hack it but i didnt succeed yet
i have tried installing voltage dividers on to the pin that directly sense it does not change the output voltage. so any suggestions on how do i hack it? |O
i cant really understand how this chip works unfortunately
datasheet http://www.sg.com.tw/semigp/data/6105/6105-datasheet.pdf
Offline madires
  • A qualified hobbyist ;)
Re: hacking atx power supply
« Reply #1 on: March 19, 2016, 07:51:29 pm »
Get an ATX PSU with a SMPSU controller at the primary side. It seems that you can't modify the sg6105dz based circuit.
Offline station240
« Reply #2 on: March 19, 2016, 08:15:24 pm »
Ugh, it has a voltage sense input for each rail, so you'd need to trick those inputs as well.
You'd be better off with a PSU with a more conventional PWM controller, for instance a TL494.
Those ICs are dirt cheap and commonly available if you wanted to retrofit the PSU you have to use that instead.
« Reply #3 on: March 19, 2016, 08:52:19 pm »
so i need to install 3 voltage deviders on those sense lines labeled v33 v5 v12 ???
is it possible to add an other chip or something like that? i have ka7500b chip witch is also from switching psu. is it possible to change it out ? for my project i need 14v output. i just really need this done with this psu. thanks in advance
« Last Edit: March 19, 2016, 08:55:22 pm by justin66 »
