Author Topic: Hacking DW01 as a cell balancer  (Read 3139 times)
Offline aruna1Topic starter
« on: September 10, 2021, 02:33:32 am »
HI All,
I'm working on a project that has a 2 cell lithium ion battery pack. Currently I'm designing the BMS circuit which has a cell balancer.
IC I chose for the purpose of cell balancing is HY2213 which is pretty cheap.
Unfortunately my component sourcing vendor has ran out of stocks of HY2213 and I couldn't find a replacement IC which is in same price range.
And then this thought came to my mind since HY2213 is infact a voltage monitor that generates an output when it sees a predefined voltage, and this behavior is similar to what li cell protection chips do during over charge, can I hack a cheap protection chip like DW01 in to a balancer?
So basically my idea is like below
since I connected CS pin to battery GND, I believe overcurrent / short circuit functionality will be disabled, and whenever it sees cell voltage above 4.25, OC pin will go low, turning on P-MOSFET which then will drain the battery until DW01 sees the release voltage.
Now I have no way to try this out in a test circuit as I don't have a DW01 at hand and ordering couple of chips will take lot of time to deliver (plus huge cost in shipping due to covid situation)
I would like to know your expert idea on this. will this work ? on better do you know any replacement for HY2213? :D
Offline NiHaoMike
    • Facebook Page
Re: Hacking DW01 as a cell balancer
« Reply #1 on: September 10, 2021, 03:31:29 am »
It will work if you're using cells rated for more than 4.25V charging voltage, a standard one designed for 4.2V maximum will degrade very quickly above that.
BTC: 18813fu8LQEdDwH9YLM1ABed3XwCfeSeFi
The following users thanked this post: aruna1
« Reply #2 on: September 10, 2021, 03:50:21 am »
Ya you are correct. but I'm running out of options.
but same will happen in battery protection circuits right? I'm not expecting to see cell in balance frequently, and I have a 2S charger IC already setup so things should not over charge
Offline NiHaoMike
    • Facebook Page
« Reply #3 on: September 10, 2021, 04:29:19 am »
How about an opamp based rail splitter, with a pair of MOSFETs to only connect it when charging?
Offline thm_w
  • Non-expert
« Reply #4 on: September 10, 2021, 09:23:19 pm »
You don't want to use a premade board right?
https://www.aliexpress.com/item/1005001636432977.html
Or build the IC into your circuit and use the premade board as a temporary solution.
« Reply #5 on: September 11, 2021, 06:43:39 am »
I tried the DW01 trick and it worked  ;D
Offline magic
« Reply #6 on: September 11, 2021, 07:13:41 am »
It seems you are looking for a low power so-called "voltage detector" IC.
Report back after the cell has spent a few years on float charge like that >:D
Offline Miyuki
  • Country: cz
    • Me on youtube
« Reply #7 on: September 12, 2021, 10:49:50 am »
Is some cheap micro too expensive or too complicated for you?
You need just one for multiple cells
It is a common solution in bigger bms
Offline Marco
« Reply #8 on: September 12, 2021, 06:04:01 pm »
What's wrong with the humble TL431?
Offline magic
« Reply #9 on: September 12, 2021, 06:25:40 pm »
It's a big power hog as soon as Vref exceeds 1V - check out the datasheet.
Its input current is 2µA, which necessitates even higher standing current in the divider to avoid error - more power wasted.
You may find some luck with those improved xx431 chips, dunno.
