Hi all,
I might be starting something here that has already been told a thousand times, but I couldn't find it. It's about the Yihua 936 clone and its thermal performance. I used a cheap HQ brand soldering station (must have been €50-100) for years, but after seeing a video of bigclivedotcom (below) I decided to buy a cheap chinese soldering station as a spare and to test how it worked. I had few little issues with the HQ brand one, but nothing major. One of them was a wire had come loose and heated the grip quite considerably. I was able to fix that before major problems occurred. Secondly, the tip had corroded solidly onto the element, so I knew that if it failed I would have to find a replacement iron too, but had no confirmed source of them because searching for HQ on internet turns up al LOT of products (eventually I found one on a
Dutch website).
After a while the soldering station did break down (element went open circuit) and I started using the Yihua one. I had actually "calibrated" the soldering iron with the Hakko clone soldering iron thermometer bigclive had mentioned (at ~12:55 in the below video). It took quite some adjustments, it was initially 100°C high, and my HQ one even more.
It did solder quite a lot less satisfatory, especially on big joints, so I decided to investigate and experiment with it, I had little to lose. Given the fact the temperature it got up to the same value and was reasonably stable it seemed to quite inresponsive. Even when cooling the tip down with some water the duty cycle of the heating element did not obviously increase, implying the thermal coupling was not optimal. This was not surprising because the tip had quite some play in it. Clive seemed to have little issue with it and just used a big bit which could store more heat, I was less tolerant and found some connections to be hard to make, especially when using my (smaller) tip on it.
To remedy it I tried to add a layer of thin 0,1mm copper foil between element and tip. I added a small amount of ceramic grease (with a 1500°C rating) to increase coupling even further (and aid the rather tight assembly). This however had little noticable effect, so I returned to just soldering more patiently and preparing for just buying a new element for my previous soldering iron, assuming the tip was just not made of a thermally conductive material. I had no thermal camera, because I was actually quite curious about the temperature distribution in the tip. I did order a new soldering iron (w/o station though) to be able to use different tips. The tip was quite stuck to the element so I could not remove it anymore and thus required a new soldering iron.
Afterwards I wanted to try the copper foil method again with the other element too. It turned out it was different, the element is ceramic externally instead of metal and it shattered when I was forcing a sleeve over it. It turns out the resistive wire is around a central rod, but there was no fill of ceramic cement at all in this one, so it does not actually physically touch the outer shell:
Does anyone have any experience with improving thermal conductivity between element and tip? Is it possible to obtain the ceramic cement that is being used to fill the element here in the EU? I'll probably switch back to the other soldering iron once I get the spares, but I like experimenting to check if a reasonable solution is possible. Right now I can't solder on large pads without bumping the temp up quite considerably (I went up to 450°C at times). There may have been topics about this before, I just could not find them.
