Hello everyone,
I'm stuck on the following problem for a while now... Forgive me if it's almost too easy for many of you guys ! Also I tried to search in the Forum whether or not the question was already asked : again, no luck
maybe I've been using the wrong keywords.
Anyway, here is the context : I have some mains-powered electric heaters that are too power hungry for my taste. I read that it's possible to use a chunky diode in series with the heater to divide their power by a factor of 2, by doing half wave rectification. (Also reducing the cos(Phi) as well, but that's not my main concern). As someone opportunely pointed out, I also need to be careful with the power dissipation in the diode, and I will probably need heatsinking.
I would like to calculate the power dissipated in the diode, so I dug out these old formulas from my textbooks :
Sine wave operation :
V
rms = V
max/sqrt(2)
I
rms = I
max/sqrt(2)
Half wave rectification:
V
rms = V
max/2
I
rms = I
max/2
V
av = V
max/Pi
I
av = I
max/Pi (Equation 1)
Then we have P
heater = V
rms * I
rms = (V
max * I
max)/4, which is half of what it would be without the diode, so I'm ok with that.
How can I calculate the power loss in the diode ? I read several times that I need to multiply the forward voltage drop V
F by "the current flowing in the diode". That's where it's not clear for me. For half a cycle, the current is (almost, if we ignore the ~1V drop, which is 0.4% of the 230V mains voltage) the same as it would be without the diode. Then for the next half of the cycle, the current is 0. (please correct me if I'm wrong)
Then what expression of "I" should I use ? I
max/sqrt(2) or I
max/2 ? I am quite lost. Also, what about the average current ?
Someone on a French forum suggested me to use the "approximate" (he said) equation P
diode = (V
Fmax * I
max)/(2*sqrt(2)) (Equation 2), but he gave no further explanation. Could someone please elaborate ?
Also, some diode datasheets refer to "Average Forward Current, I
f(av)". Do they refer to the real average current (which is, if I'm not mistaken, the equivalent DC current) or to its RMS value ?
Some datasheets even come with a power loss plot, such as
this one (fig. 8, page 4).
To see how Equation 2 would work, and to have something to compare it to, I imagined a load which would draw an average current of 10A. Then, using Equation 1, I calculated I
max, and then using Equation 2, I got a result of P
diode = 11.7W, which is a bit higher but not too far off what I can see in fig. 8 of the datasheet for this current.
Many thanks in advance to anyone who could clarify this for me !
Cheers
JF
PS : I also found AN 604 from ST, "Calculation of conduction losses in a power rectifier" ,
here but I'm not sure I want to go into this level of detail and take junction temperature into account, I guess I would just need a ballpark figure to choose a heatsink. Besides, according to fig. 8 of AN 604, the conduction losses decrease with temperature ; the worst case (ambient) may be just fine for me.
