Author Topic: Halogen vs LED  (Read 2418 times)
Offline HextejasTopic starter
Halogen vs LED
« on: October 09, 2019, 05:58:46 pm »
Say, can i replace a halogen lamp bulb with an LED bulb ? I think not but thought I would ask
and here is a picture of the bulb and spec sheet.
« Last Edit: October 10, 2019, 01:23:01 am by Hextejas »
Offline schmitt trigger
  • Country: mx
Re: Halogen vs LED
« Reply #1 on: October 09, 2019, 06:06:17 pm »
There are LED replacements for Halogen lamps offered from many vendors.
Although the power consumption will significantly decrease, the CRI will suffer.
Halogen lamps are the CRI champions.
Offline Gyro
Re: Halogen vs LED
« Reply #2 on: October 09, 2019, 06:10:36 pm »
It's probably a good idea for you to take a step back before posting a question, and asking yourself what sort of background information and details you should provide, in order of people to stand a chance of being able to sensibly answer it.
Best Regards, Chris
The following users thanked this post: Someone, thm_w, nuclearcat, jhpadjustable, SiliconWizard
Offline Someone
    • send complaints here
Re: Halogen vs LED
« Reply #3 on: October 09, 2019, 08:35:28 pm »
Yes
Why do you think not? I think yes.
Offline ejeffrey
Re: Halogen vs LED
« Reply #4 on: October 09, 2019, 09:02:13 pm »
What type of lamp?
Re: Halogen vs LED
« Reply #5 on: October 10, 2019, 01:49:27 am »
If I did the google search correctly, it looks like there are a lot to try. The spec sheets are daunting.  :palm:
Offline SiliconWizard
Re: Halogen vs LED
« Reply #6 on: October 10, 2019, 12:56:17 pm »
But what's the application? Looks like a bulb for cars or something, but just tell us what it is used for.
Offline mariush
Re: Halogen vs LED
« Reply #7 on: October 10, 2019, 03:14:28 pm »
The halogen says 14v 35w ... in fact you can still buy the bulbs : https://www.eevblog.com/forum/projects/halogen-vs-led/
You can assume that's 14v AC and I guess it's supposed to be used with lamps or things that use a dumb 12v AC transformer inside to provide isolation from mains.
You could use LEDs but first you must convert the AC to DC using a diode (cheap but led would be off half the time, so you'd get flicker) or a bridge rectifier (for full wave rectification, less flicker)
Then you'd add a small capacitor to smooth the rectifier voltage and then you'd want to limit the current going through the led otherwise it would burn up.
Now you get a LED with a forward voltage less than your average DC input and you need to limit current going through it otherwise you'll damage it.  Either use a plain simple resistor or use a led driver
Offline Zero999
  • 0999
Re: Halogen vs LED
« Reply #8 on: October 11, 2019, 09:30:13 am »
A capacitive dropper can be used before the rectifier to save burning off lots of power in a resistor.
Another option is to look for retrofit LED bulbs which can replace halogen bulb, with no extra components: the bridge rectifier and current limiting circuitry is built-in.
Offline tooki
Re: Halogen vs LED
« Reply #9 on: October 11, 2019, 10:09:51 pm »
Be sure to throughly clean that bulb with isopropyl before using it again; the skin oils deposited by handling with bare hands cause hotspots on the quartz envelope which will cause it to fail.
« Last Edit: October 11, 2019, 10:13:56 pm by tooki »
