Hey guys
I’d like to ask you if it would be possible to make a hand held photo camera that could take 360 panoramic pictures via 5 or more cameras which would be arranged so that the photos could be stitched into 360 panorama image, like the ones in google street view.
In my opinion the hardest part of this project would be creating software which could recognize where the images should be stitched seamlessly, because the end of one image wouldn’t be the beginning of the other. And also I would imagine the stitching part would be done externally with a smartphone or a table as it requires a lot of processing power.
As far as my research showed there’s no such product on the market. The only thing that comes close is the
Ricoh Theta 360 - degree camera But the way I see it, it has three big shortcomings.
1. It only has 2 cameras so uses “Fish eye” lenses to get that 360 image, which also gives warping effect to the pictures.
2. The “Fish eye” lenses stick out way above the housing which makes them extremely vulnerable to scratches and if dropped to braking altogether.
3. Also the “Ricoh Theta 360 - degree camera” doesn’t have flash so no clear pictures at low light.
So I’d really like to hear your opinion from a technical point of view, is it technically possible to make such camera and make it the size of a “Neurolizer” as seen in M.I.B movies?
Thank you for your answers
