Author Topic: Has anyone ever seen a part like this?  (Read 1154 times)
Offline nomar123Topic starter
« on: August 16, 2022, 06:43:18 pm »
Hi all, I am attempting to refresh an old design that used this IXYS Bipolar MOS Transistor:
https://www.littelfuse.com/media?resourcetype=datasheets&itemid=9ea3c719-1918-46a5-8b61-c939be5aabf8&filename=littelfuse-discrete-igbts-smpd-packages-mmix4b20n300-datasheet
Pretty specific part and package, which is making me think this was a custom part for their application way back in the day. It does not seem like there is stock of any IXYS parts out there, a quick google search sows that IXPS was bought by littlefuse in 2018...anyone know anything about IXYS? Or know of any other vendors that make similar high voltage, high gain transistor arrays?
Online Benta
Re: Has anyone ever seen a part like this?
« Reply #1 on: August 16, 2022, 07:07:10 pm »
It's a full-bridge IGBT power stage for power conversion or motor control. Nothing really special about it.
Offline jmelson
« Reply #2 on: August 16, 2022, 10:25:16 pm »
Uhhh, 3000 V 14 A??!!??  That sounds pretty special to me!
Jon
Online T3sl4co1l
    • Seven Transistor Labs
« Reply #3 on: August 16, 2022, 10:55:59 pm »
Unusual, but not unheard of.  Hm, not bad switching speed for that voltage, nice.
The big problem is finding something as compact, or SMT, or whatever other features you want to keep; I would have to guess they needed a compact outline, and perhaps you still need it as small.  You aren't going to replace that with D2PAKs, for example.  Though there may be some special D2PAKs (Kelvin leads, adequate spacing to drain/collector) say with SiC inside, that do that; or, D3PAKs go that high in voltage, but definitely won't fit in the same footprint.
If this is for something like a motor switching application, where speed isn't a big deal, there are integrated modules, even with gate drivers included; I don't recall offhand if they come this high in voltage, but it may be worth a look.
IXYS has been around quite a while, though they did get borged in 2018 yeah; they have a penchant for unusual and niche parts (or, did), of which this is surely one of them.
Gate drivers, are probably going to have to be fully isolated; I'm not aware of any HVIC bootstrap style parts that go over 1200V (though maybe that's changed now that 1700V SiC are common on the commercial market).
I suppose the medium-voltage input is also not negotiable, but if that can be pushed back on, there might be a lot of savings -- not just in component selection, but insulation, safety and transient immunity requirements as well.
Seven Transistor Labs, LLC
Offline TheMG
« Reply #4 on: August 16, 2022, 11:01:48 pm »
Jon
Perhaps to someone who doesn't deal with high power electronics on a regular basis. However, parts with ratings like this are extremely common nowadays in things like motor VFDs, UPS, inverters, etc. I would actually consider that 3000V 14A device to be a relatively small one, they are available with ratings into the hundreds of amps.
Quite often they'll cram more than one IGBT into a single "brick", along with power diodes and such. These are available in a number of different standard/commonly used configurations but of course could also be customized for an application. Of course, single IGBT are also available. Many manufacturers make them.
Online coromonadalix
« Reply #5 on: August 16, 2022, 11:05:53 pm »
loll pretty ordinary loll   seen some IGBT at 800v 2400 amps
Offline Terry Bites
« Reply #6 on: August 19, 2022, 12:10:09 pm »
Copyright infringement. You cant just sample my letters and add a bit on!
Neuh!
Offline abquke
« Reply #7 on: August 19, 2022, 12:17:51 pm »
IXYS was the go-to for really burly power switching stuff (SCRs, IGBTs) once upon a time. I caught an error on one of their datasheets once. Hopefully they don't suck after the acquisition...
