Thanks again for the reply
I attached an image of the HC-06 modules. I marked 2 missing components on these boards, but seeing as it pairs ok, I guess they are not needed.
I recently received another couple on HC-06's with a HC-05 from yet another vendor. I could use the HC-05 fine (with minor mods for connections), but the 2 HC-06's still had the same problem. As mentioned, the AT commands work fine, I can change the baud rate and the communicate with more AT commands in the new baud setting, and it pairs and sets up a COM Port on the PC.
When I start my Win application and select the COM Port that was allocated for the HC-06, the LED stops flashing and stays on indicating that the link is active. If I close my PC app, the link is broken and the LED starts flashing again which is normal. It's just the serial comms do not work on any of these boards.
The trouble with searching for working units, is the time it takes with no guarantee that the next batch you buy will work, (+ the $ involved). I tried to ask specifically for the Blue LED variety which always work, but the vendors cannot guarantee sending them. I bought 2 separate lots of 20 modules, only one had the blue LED, which worked fine, the other 39 didn't work. Maybe I'll just have to give up on them and use something else. I tried JDY-31, but the ones delivered were in a simple plastic bag and I could not get them to work at all. As indicated, maybe more HC-05's or maybe HM-10, but I'll need patch boards to connect them to my current boards.
