Author Topic: Heart rate sensor?  (Read 3149 times)
Offline chebebaTopic starter
Heart rate sensor?
« on: March 12, 2014, 08:22:04 pm »
For heart rate sensing, I have seen many products that you wear close to your body, usually as chest straps.
I wanted to design a similar sensor into a thingie I'm building.
The web has plenty of app notes and DIY descriptions of how to do it when you shine a light through a body part, most of the time a finger. But my Google skills fail me, I cannot seem to find any description of how to do it when you just have proximity, as with a chest strap.
Anyone done such a sensor and want to share how it works?
Offline NiHaoMike
    • Facebook Page
Re: Heart rate sensor?
« Reply #1 on: March 12, 2014, 08:35:41 pm »
Look up EKG and pulse oximeter.
BTC: 18813fu8LQEdDwH9YLM1ABed3XwCfeSeFi
« Reply #2 on: March 13, 2014, 06:08:34 am »
OK, seems I need to clarify ;-)
Oximetry (in the implementations I have found so far) requires, as I mentioned in the OP, to shine a light through a finger. So you need a ring or clamp or something like that. Not what I am looking for.
EKG (in the implementations I have found so far) requires electrodes attached to the skin using conductive wet gel. Not what I am looking for.
There are many product that sense heart rate that does not require this (Google "heart rate chest belt"). But I have not been able to find schematics or even textual descriptions on how these sensors work.
So my question is basically: How do these chest belts work, I'd like to make a similar circuit.
Offline Dago
    • Electronics blog about whatever I happen to build!
« Reply #3 on: March 13, 2014, 06:47:56 am »
The belt just basically has a couple of electrodes (conducting rubber) that are attached to some very high input impedance op-amp amplifier circuit which amplifies the signal (also has stuff like low-pass filters, 50/60 Hz rejection filters etc. usually) which is then sampled by a microcontroller and after some signal processing you can figure out the heart rate.
I think these might be good for what you are doing: http://www.plesseysemiconductors.com/epic-plessey-semiconductors.php I was thinking of doing something with them for fun at some point.
Come and check my projects at http://www.dgkelectronics.com ! I also tweet as https://twitter.com/DGKelectronics
« Reply #4 on: March 13, 2014, 12:06:58 pm »
Thanks, the EPIC looks like a good product for me. A little pricey at EUR 25 per chip for a glorified OpAmp, but that's OK  ;D
Offline Dago
« Reply #5 on: March 13, 2014, 01:56:53 pm »
The Plessey EPIC-sensors are under 7,5€/piece at Mouser: http://fi.mouser.com/Search/Refine.aspx?Ne=254016&N=1323038+7454634+4290079590
