Hello!
I bought a "rasperry pi compatible" Sony IMX290 image sensor module and I'm testing it out on a custom (non-RPi) Linux development board (unfortunately I don't have a RPi on hand). When I ran i2cdetect, 2 addresses are shown: 0x1a and 0x36.
The first address, 0x1a, is expected: as per the datasheet, this is the slave address of IMX290. I was not expecting the 2nd address of 0x36. After checking the
schematics of the official Raspberry Pi Cam v2 module, there seems to be an additional
crypto IC that's connected to the same I2C bus, apparently for preventing the production of unauthorized clones.
In the datasheet of the crypto IC, I did not find any info of a slave address (it only says the slave address is stored in the Configuration zone; could this mean that the address is not fixed?) On my IMX290 module I didn't find the same crypto IC, but an unknown 6-pin IC that seems to be connected to the I2C bus, with markings "24N", followed by what seems to be a "17" rotated 90 degrees anticlockwise (please see attached image). I would greatly appreciate any pointers on what this chip could be and whether could it be the source of the mysterious 0x36 address.
Thank you.
