I built the
ATMega328PB circuit below (1.png).
It runs at 3.3v from 1.5v battery using
booster and 8MHz from external resonator
CSTCE8M00G52A-R0.
Using USBTinyISP I set fuses: Low-FF (for 8MHz), High-D8 (Boot Reset Vector Enabled), Ext-FD.
Using VisualStudio and vMicro plug-in I compiled a program for UNO. vMicro created a HEX file of my program WITH a bootloader which I uploaded over ISP and it runs well (blink the LED).
My final goal is to make a customized 8MHz bootloader but as intermediate step
I am trying to get a sign of life over serial using
FT231X FTDI.
I cut the 5v jumper on the FT231X and connected the 3.3v jumper instead.
Then connected (without battery):
ATmega328 FT321X
VCC VCC
GND GND
GND CTS
RST DTR (over 0.1uF)
RxD TX
TxD RX
Since the default UNO bootloader UBRR register is set for 16MHz, I initialize it manually and try to push data over serial.
#define myubbr (8000000/16/9600-1)
void setup()
pinMode(6, OUTPUT);
// Init serial
UBRR0H = (unsigned char)(myubbr >> 8);
UBRR0L = (unsigned char)myubbr;
UCSR0A = 0;//Disable U2X mode
UCSR0B = (1 << TXEN0);//Enable transmitter
UCSR0C = (3 << UCSZ00);//N81
void loop()
digitalWrite(6, HIGH);
delay(100);
digitalWrite(6, LOW);
delay(100);
char * str = "Hello World";
while (*str) {
while (!(UCSR0A & (1 << UDRE0)));
UDR0 = *str++; //send the data
On the PC I run: avrdude -v -p m328p -c arduino -PCOM8 -b 9600 (see COM PORT settings in 2.png below)
Avrdude recognizes the correct com port but gives:
avrdude: stk500_getsync(): not in sync: resp=0x00
The RX and TX LEDs on the FT231X never blink.
I don't even know if the problem is HW or SW. What am I doing wrong. What else can I try?
