Author Topic: Help identifing connector  (Read 1301 times)
Offline CAPFXTopic starter
« on: January 29, 2019, 02:56:15 am »
I'm looking for this connector but I'm not having much luck finding it (or even what this style of connector is called). It's 2x14 and 2x5 contact positions on the same connector housing bit. Not shown in this image (I'll get better ones tomorrow) but there's a 28 pin ribbon cable on one side and 10 pin ribbon cable on the other side. They go into some sort of split ribbon cable IDC housing thing with slots for 28 cables, a space, and then slots for 10 cables. For those curious, it's on a Powerflex 523/525 drive.
Offline gnif
  • Views and opinions are my own
Re: Help identifing connector
« Reply #1 on: January 29, 2019, 05:07:52 am »
It looks very much like a SATA/SAS connector that you would see on a HDD although from the picture it seems there are pins on both sides of the fingers which is inconsistent with those connectors.
https://p.globalsources.com/IMAGES/PDT/B1065662480/Female-SAS-Connector-with-29-Pins.jpg
« Last Edit: January 29, 2019, 05:11:04 am by gnif »
Offline envisionelec
« Reply #2 on: January 29, 2019, 05:42:20 pm »
It’s known as a MICTOR connector.
