Class D has its place.. but I would argue a hifi amplifier is not one of them. I'm sure there ARE Class D implementations that are very very good, but the cheap Chinese kits are not amongst those.
It's easy for the big boys to get caught out on this as well - Rotel released a Class D amplifier. It turned out to be useless if you tried to use it with an FM tuner, because the Class D PWM noise radiated out of the speaker leads and swamped out the FM reception!
There's plenty of kits for Class AB, though again watch out for crap Chinese kits on eBay - usually poorly designed and with fake output transistors.
A good start is Rod Elliot's P3A Amplifier -
http://sound.whsites.net/project3a.htm. I personally like to use MJE350 for Q4, and MJE243/253 for Q5/Q6. You can even get away with TIP2955/TIP3055 outputs if money is tight
