Hi MariuszD
As shown in the image below, this is a step-up circuit board built using the MC34063; it takes a 4.2V lithium battery input and provides a 9.0V output.
In the output section, an SS8550 transistor is also used for shutdown control; why, then, does this circuit not require a 470-ohm resistor? The difference lies in the output voltage—9.0V versus 5.4V—even though the SS8550 transistor is used for the same shutdown control function.
To be honest, the output shutdown circuit for my TPS61040 design—using the SS8550—was based precisely on this circuit.
You can see that in the MC34063 circuit, the emitter, base, and collector of the SS8550 are not connected to any resistors; however, in my TPS61040 circuit, I specifically added 100kΩ and 200kΩ resistors.
Thanks
