Author Topic: Help, can I use another oxygen battery instead?  (Read 1131 times)
Offline daisizhouTopic starter
  • Country: cn
« on: May 28, 2022, 02:44:06 am »
One of my test instruments originally used psr-11-75-ke oxygen battery, because psr-11-75-ke is hard to buy, I plan to replace it with ordinary oom202 oxygen battery.
I inquired about their 2 kinds of oxygen batteries, the output voltage is different, I don't know if they can be used instead?
If it can't be used directly instead, can a voltage conversion circuit board be added to change their output voltage, and then connected to use?I mean add a small circuit board, adjust the new battery to the same linear range as the original battery and use it again.
If you know please help me, thanks
« Last Edit: May 29, 2022, 01:35:39 am by daisizhou »
daisizhou#sina.com #=@
Offline free_electron
    • SiliconValleyGarage
Re: Help replace oxygen cells
« Reply #1 on: May 28, 2022, 05:00:50 am »
These are all made by Figaro.
  • Country: cn
« Reply #2 on: May 28, 2022, 06:41:35 am »
Can I use oom202 instead of psr-11-75-ke?
Their output voltages are somewhat different
  • Country: cn
Re: Help, can I use another oxygen battery instead?
« Reply #3 on: May 29, 2022, 01:27:01 pm »
please, who can help me
