Author Topic: High(ish) frequency bootstrap circuit for high side switching  (Read 4994 times)
Offline DmeadsTopic starter
  • who needs deep learning when you have 555 timers
« on: September 10, 2019, 02:59:29 am »
Hello!
I watched this video on high side switching with a bootstrap configuration for an NMOS. the attched pic is my circuit.
Problem is, with such a big cap, it cant switch the load fully off at frequencies above ~50Hz
I tried smalled caps and got better results, but then the load (light bulb) didnt fully turn on. (maybe smaller cap didnt charge to high enough voltage?)
How can i increase the switching frequency to say maybe 100KHz?
Offline brabus
Re: High(ish) frequency bootstrap circuit for high side switching
« Reply #1 on: September 10, 2019, 09:08:02 am »
The MOSFET Input Charge plays a major role in defining the minimum capacity required for the Bootstrap.
The Bootstrap diode is also quite critical; most drivers integrate a synchronous switch.
100 kHz is in any case an ordinary frequency, you should manage it without needing to go for a charge pump circuit.
Can you elaborate a bit more on your circuit? Which components have you used?
The following users thanked this post: Dmeads
Offline Zero999
  • 0999
« Reply #2 on: September 10, 2019, 09:57:07 am »
It's not the capacitor which is limiting the upper frequency. It only limits the maximum on time, which is proportional to the capacitor size.
The 10k pull-up resistor is limiting the current to the MOSFET gate, which acts as a capacitor. The extra RC circuit, slows down the switching speed.
Another transistor is required to quickly turn the MOSFET on.
I'd recommend using a high side MOSFET driver IC, which will have other features such as undervoltage lockout, which will prevent turn the MOSFET off if the voltage on the bootstrap capacitor is too low to keep it hard on. Without undervoltage lockout, the MOSFET will get hot and overheat, if the voltage on the bootstrap capacitor is low and the driver keeps it on, as it will be in the linear region, with a high current and volt drop across it. There are plenty of high side driver ICs. Here's one I found by doing a quick Google for high side MOSFET driver.
IR2127PBF
https://docs-emea.rs-online.com/webdocs/0791/0900766b807910ad.pdf
« Last Edit: September 10, 2019, 10:11:57 am by Zero999 »
