If size is an issue, the powder cores can have an advantage, as there maximum B field is higher (e.g. a factor of 2) than with ferrites, if not limited by core loss (e.g. high ripple and frequency). The µ of the powder cores is limited, which corresponds to a kind minimal gap. The high µ powders can be conductive and thus higher loss. With ferrite one is flexible to adjust the gap.
