Author Topic: High Current Inductive Load Switching Issues  (Read 1097 times)
Offline Pizzashape23
« on: September 18, 2020, 03:18:19 am »
I recently made a post about a safety circuit for a high current solenoid which was being used to feed a smelting furnace. That post is much more detailed but probably not a necessary read to understand my Issue.
After ordering and assembling the trigger circuit for the solenoid, it is a low side mosfet switch using the NVMFS5C604NL from On Semi triggered by a photo interrupter, it worked great for about a day. After a while I noticed the solenoid was staying on for way longer than it should have been, upon closer inspection my mosfet had failed short and thankfully my safety system had worked. As I was switching a really big inductor running upwards of 40A through it I figured it was a voltage spike when the mosfet switched off that had killed it, turns out my flywheel diode had died and probably took the mosfet with it.
I replaced the mosfet, and hoping for a quick fix, putting two of the same diodes in series, at the time I figured I might have been on the upper voltage limit of the diodes. The cirucit started working again but only survived half a day this time, the mosfet was dead but according to my multimeter the diodes were still fine.
I don't have any tools that can properly trouble shoot a circuit with such high current and potentially very high voltage spikes, so I was wondering if anyone could provide any insight on what went wrong, particularly why the mosfet died while the diodes survived. They are FERD60M45CT's.
I'm pretty sure that I just don't have the right diodes, but I don't really know what to look for in a flywheel diode. If anyone could point me in the right direction or recommend a specific part, any and all help would be appreciated.
As a side note: The solenoid is running at about 26V, has a resistance of 0.6ohms and an inductance of around 3.3H. The mosfet is getting 12v at the gate.
Offline TimNJ
Re: High Current Inductive Load Switching Issues
« Reply #1 on: September 18, 2020, 04:34:17 am »
I think you want a diode with fast forward recovery time. Most datasheets don't specify forward recovery...just reverse recovery. I think it may be true that a fast reverse recovery implies a fast forward recovery. Forward recovery just means the time it takes to go from a non-conducting to conducting state. This diode needs to "catch" the inductor energy before the voltage builds up across drain-source, as you know.
43A + 3.3H means the peak voltage can be very high..depending on di/dt at switch-off. You can simply try to slow down the MOSFET shut-off transition time. Since the voltage spike is a product of di/dt, if you use a higher value gate resistor, the peak voltage should be lower.
Also, 43A through 1.3mOhm RDSON is over 2W dissipated in a poor little DFN5x6. Do you have plenty of copper area on your PCB? I've used that package before, but kept it to less than ~0.5W, since there wasn't much available area for PCB heatsinking. Check Note 2 on the datasheet. The thermal resistance from junction to ambient is 39C/W with a 25mm x 25mm 2oz copper area. That's a pretty large area, and even then you'll get 85C rise @ 2.2W
« Last Edit: September 18, 2020, 04:39:42 am by TimNJ »
Offline exmadscientist
« Reply #2 on: September 18, 2020, 04:40:22 am »
Slowing down the FET has the opposite problem: now it's in linear mode dissipating heat for a longer period of time, which heats it up and tends to induce thermal runaway. This is a pretty good way to kill FETs. So this is something that's not trivial to balance well. I think I usually see more people err on the side of fast switching and then deal with the pulse, but this inductor is on the larger side, so one must be careful....
Speaking of gate transition times, what's the gate driver here?
« Reply #3 on: September 18, 2020, 05:05:13 am »
Yeah, I get where you are coming from, but at the gate voltage that it is being driven at the 1.3mohm is much closer to 0.8mohm. I also made sure to include a massive copper area with large thermal vias going to more copper on the other side, i also filled in the vias with solder and made sure to layer it on both sides. This does still have it's limtations which is why I am trying to reduce the on and off times as much as possible, there is no gate resister and the gate to ground resistor is 100ohm.
The gate driver is a super simple board of my own design, it takes the output from the photo sensor, inverts it using an npn transistor then drives a pnp transistor directly switching the mosfet to the lower voltage supply rail at 12v. I don't have a schematic right now, but if it's needed i could put one together.
I really think it's an issue with the snubbing of the voltage spikes, in testing I was able to keep my finger on the mosfet while it was switching multiple times which means that it isn't getting very hot. I tried to keep the entire switching ciruit as simple as possible so that troubleshooting and repair would be fairly easy.
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #4 on: September 18, 2020, 05:26:50 am »
What is the switching loop, from GND, to MOSFET, to catch diode, to supply, to GND?
There should be a bypass cap right beside the transistor and diode.
What does the drive circuit look like?
Seven Transistor Labs, LLC
Offline TimNJ
« Reply #5 on: September 18, 2020, 05:30:17 am »
Depends on how frequently it's being switched? If you're actuating once a second continuously, maybe not a great idea, but once every few minutes, I can't see how it would run away. I'm also not suggesting to slow down the switching time to something ridiculous. But I don't think it needs to switch in (a few) nanoseconds either.
« Last Edit: September 18, 2020, 05:36:52 am by TimNJ »
« Reply #6 on: September 18, 2020, 05:48:20 am »
Sounds about right to me, yeah. The selected MOSFET is pretty robust and might even be able to get away with a gate transition time as low as a millisecond or so.
I guess I've been spending too much time with less-forgiving HV superjunction parts lately, where that's a relative eternity!  :-BROKE
« Reply #7 on: September 18, 2020, 09:44:36 am »
The "driver" is attached, please mind the hand writing, its only a rough sketch.
It works in conjunction with the safety circuit mentioned in the other post, in a fail state the relay should prevent the solenoid from being active for longer than would cause damage .
Also the solenoid is being activated once or twice a minute, when in use. This means I would much rather correctly spec the snubber circuit than try to reduce the switching time. I was lucky the first time it failed because I was in the shop and I could see that it had failed short, I dont want to risk a thermal runaway while someone else is using it as they probably wont see it fail and try to conti ue to use it.
Offline TimNJ
« Reply #8 on: September 18, 2020, 03:41:33 pm »
Your "switching frequency" is about 0.03Hz if you actuate twice a minute. I think the fear of thermal runaway is not 100% relevant in this particular case.
What's the approximate rise time of the drain voltage during switch-off, as is? Here's a worst case SOA approach:
The peak power dissipation in the device (theoretically) happens when Vds = 0.5*Vdd and Ids = 0.5Idd. This can vary a little based on gate characteristics. But, let's just try it. 0.5*26V = 13V; 0.5*43A = 21.5A. Looking at the SOA curve from the ON Semi datasheet, we see that this roughly aligns with the 1ms curve, meaning it can handle a pulse with the aforementioned power for 1ms or less. In reality, the MOSFET only sees the peak power for part of the switching cycle. Theoretically, the power waveform roughly looks like a half sine wave. You can probably estimate that the real power capability (or max pulse duration) is at least 20% higher.
My point is: You don't have to slow the thing down to 1ms if it makes you uncomfortable, but you also don't need the switching time to be 50ns. Somewhere in between may get the peak voltage down to something reasonable. Of course, you can just take care of it with snubbers, flyback diodes, maybe even TVS...but there too you need to understand peak power handling etc.
« Reply #9 on: September 19, 2020, 01:19:45 am »
That's a great response and makes sense, but it would also imply that the culprit of the mosfet death is definitely the voltage spikes and also that the snubber i have got in place is working temporarily but still not doing its job properly.
If im not mistaken the switching speed is based on how hard the mosfet gate is driven, so adding a gate  resistor should slow it down. How would i find the right resistance value?
In my case it is much easier to fix the snubber than to add a resistor as the pcb has already been printed, in hindsight i should have added pads for it and just bridged it with wire. Even If i end up
having to slow it down, I am still curious about how i would have correctly spec'd my snubber and would probably include it anyway just to be safe.
Something im still confused about is why after adding another diode in series with the first, the mosfet lasted half as long.
Offline julian1
« Reply #10 on: September 19, 2020, 02:14:55 am »
Because the flyback voltage got worse after it was blocked by an additional slow switching diode?
Are you able to wire in a jelly-bean schottky 1n5822 as a test. Only 3A but it merely has to shunt the voltage spike for an instant ( "once or twice a minute") . Unless I am misunderstanding something.
« Reply #11 on: September 19, 2020, 02:35:20 am »
It makes sense for normal diodes, but the ones I have used are schottky diodes, they should be switching fairly quickly.
Sure, if they are in stock at my local altronics i might be able to pick some up today and try it. But I don't think it will make much of a difference, the max reverse voltage is only 40V no where near the voltage spikes.
Offline julian1
« Reply #12 on: September 19, 2020, 02:56:53 am »
The reverse voltage of 40V is sufficient to stand off the 26V of your supply. To shunt the spike it's forward biased no? And it should shunt/cap to limit the spike to lower than that to protect the FET drain.
The FERD60M45CT datasheets states they are a 'Field effect rectifier '. I have no idea what that is.
Offline TimNJ
« Reply #13 on: September 19, 2020, 03:03:13 am »
In general, I would find the value experimentally. Start with a few ohms (1 to 5, maybe) and move up from there until you reach the desired rise/fall time.
Before trying to implement any solution, you should really put a scope across drain-source to see what it looks like right now. 10x probe should be good up to ~500V, and given this is a 60V MOSFET which worked for a little while, doesn't seem like it is too much more than 60V...maybe 100V-ish?
Can you share a picture of your board? Or a screen-capture of the layout?
Offline TimNJ
« Reply #14 on: September 19, 2020, 03:09:43 am »
Maybe this is a dual "diode-connected" MOSFET type thing? If so, seems like a bit of an odd choice. Seems that these are targeted at some special application, but I do not know what.
« Reply #15 on: September 19, 2020, 03:30:20 am »
Sure, it worked for a little while, but it did have the "schottky diode" across the solenoid, and that's what is confusing. Without the diode the mosfet blew after the first trigger, using one diode it survived about a day and using two diodes about half a day. I also don't think that such a large solenoid with such high current would generate spikes of only 100V.
Note that on the arrow.com listing it said it was a schottky diode
The board is attached below, the 4 terminal connector goes to the sensor while the 2 terminal connector goes to a regulated 12V. The leads go to the solenoid and gnd
« Last Edit: September 19, 2020, 03:36:05 am by Pizzashape23 »
Offline T3sl4co1l
« Reply #16 on: September 19, 2020, 03:40:01 am »
Ah, that answered my question then.  It's not.  Quite possible the loop length is causing excessive peak Vds.
How long is the cable from MOSFET to clamp diode, and to the supply?
« Reply #17 on: September 19, 2020, 03:50:27 am »
The length from mosfet to diode is about 30cm and can be cut down, but if loop length does cause issues it might be coming from the metre between the diode and the supply.
Could you explain how that would increase Vds?
Offline T3sl4co1l
« Reply #18 on: September 19, 2020, 04:48:28 am »
Wiring has inductance too.  The whole path from MOSFET to diode to supply (assuming the supply has a big fat capacitor in it) and back gets charged by the load current, then discharged when it turns off.  V = L * dI/dt simply generates excess voltage proportional to the rate of current, and if that exceeds the transistor rating, it will avalanche.  It might not fail right away, or even after many cycles, but it tends to lead to failure and I recommend against using MOSFETs in repetitive avalanche breakdown.
So then, how fast does it turn off?  Without a scope waveform, we can still simulate it, or estimate it from component values.
Using this datasheet: https://www.onsemi.com/pub/Collateral/NVMFS5C604NL-D.PDF
If we assume Vgs = 12, and the BC327 turns off*, then we have 100 ohms discharging the gate capacitance.  Drain is carrying ~40A.
*For best results, there should be some resistance B-E to ensure it turns off cleanly.  Anything from 60 to 10k ohms would be fine here, I think.  Should still work as-is, though.
Following this instant, Vgs discharges.  Ciss is about 10nF so this goes exponentially with a time constant of 1us.
Nothing much happens until Vgs ~ 3V, where Rds(on) increases hyperbolically.  Vds starts rising, and Vgs levels off -- the Miller plateau.
The Miller plateau takes about 13nC.  While Vgs is in the 2-3V range, Ig is 20-30mA, so the plateau will be about 0.5us long.  In this time, load current is still 40A (that big fucking inductor isn't going anywhere :-DD ) and Vds has risen to its peak (whatever that is).
As the plateau ends, Id finally drops, and we can calculate dI/dt.
g_FS = 180S
Ciss = 9nF (it's dropped slightly, because Vds is high; the difference is basically Crss)
Ig = 20-30mA
Ig = Ciss d(Vgs)/dt ==> d(Vgs)/dt = 2.2-3.3 V/us
dI/dt = d(Vgs)/dt * g_FS = 400-600 A/us
Vpk = Lloop * dI/dt = well, a lot even if Lloop is a mere 0.1uH.  Which it's definitely not (that would be about 20cm of cable for the entire loop), so for sure, it will avalanche.
How much avalanche is permissible?
Datasheet gives one-shot rating for Ipk = 22A, E = 776mJ (which means it's a pretty darn big die, barely any plastic making up that SMT package, I suspect).  There's a curve, Fig.12.  Say we pick the hot condition, Ipk = 40A.  That gives 0.6ms.
If Lloop ~= 0.8uH, and V(br)dss = 70V typical, then Vloop is 70-26 = 44V, so the 0.8uH will discharge from 40A to 0 in
dt = L * dI / V
= 0.7us
which sounds pretty safe versus 600us.
No repetitive figure is given, so it's not obvious how many shots of this it can withstand.  Unlimited?  Does it cause wear, and if so how much?  It's about 1/1000th the maximum, but does that mean it can handle 1000 shots?  Maybe it doesn't derate proportionally, maybe it's only ~30 shots?  Maybe it's unlimited?  Is the plot even for a single event, or what?
Possibly, a manufacturer FAE could answer some of these questions; it will be faster to change the circuit and try again, though (at least, for a couple tries).  Might still be worth a shot.
I also wonder about the path between solenoid GND and the 12V supply: are they common ground (elsewhere)?  Isolated?  What length of wiring?
I think it would be pretty safe to put a SMAJ36A from source (anode) to drain (cathode), and a 1N4745 or such from GND to +12V.  This at least prevents hazardous voltages from reaching the transistor itself.  I would try that and see.  (This clamps voltages locally, without needing to reroute power lines or add a capacitor.)
Some filtering on the optointerrupter leads might also be desirable. Preferably this circuit would be placed nearby..?
Also, how hot does that thing run in practice?  Might be worthwhile soldering a copper fin on it, or a soft thermal pad and heatsink.  Shouldn't need much to dissipate a couple watts.
The following users thanked this post: Pizzashape23
« Reply #19 on: September 19, 2020, 06:11:33 am »
Look, you went in to way more detail than i expected, and while I can appreciate it, im going to be honest and say that most of it went over my head.
I will answer what i can and say that the 12v supply is derived using a dc/dc converter module directly from the supply of the solenoid at 26 or so volts. The photo sensor is less than 5cm away from the trigger circuit and while the mosfet was working it did not run very hot (Keep in mind i was not able to monitor it constantly). Also i think it is important to know that the supply at the moment is 2 12v lead acid car batteries, I planned to change it after i could see that the system was working reliably.
My questions now are;
(Before reading these questions, a couple will probably be pretty stupid, keep in mind this is my first time using mosfets and i acknowledge that i am way over my head. However, I am definitely keen to learn.)
-Is there anyway to avoid avalanche/failure entirely?
-If running at avalanche does cause lasting damage and thus the life span is temporary, would there be any way to extend it or reduce the risk of failure?
-When you said that the zener should go from GND to 12V, could it go directly across the input terminals of the board or does it need to be near the mosfet?
-What is the zener diode doing?
-Why is it that the mosfet can handle being in avalanche for any amount of time?
-Im assuming that while in avalanche as long as the breakdown voltage is not exceeded and it's not avalanching for too long it might survive, is this correct?
« Last Edit: September 19, 2020, 06:49:05 am by Pizzashape23 »
Offline T3sl4co1l
« Reply #20 on: September 19, 2020, 08:11:20 am »
Ahh... and I guess the converter is common ground, a three wire module more or less?
That sounds alright.
Yes!  Divert the excess voltage into a clamping device.
Technically, TVS diodes also avalanche; they're just more reliable at it.  We could still dodge that, if we wanted to -- say by using a clamp diode into a large capacitor (this is called a voltage peak clamping snubber).
The MOSFET by itself, can dissipate a fair amount of power for a short time, at pretty much any voltage or current it can handle.  Avalanche occurs when the voltage is pushed too high (avalanche breakdown), somewhere above 60V.  This is a different sort of current flow (there's physics under there), and it cannot be controlled by gate voltage.
One way to avoid this type of current flow, is to make the transistor turn on, just enough to hold drain voltage below breakdown.
Which can be done with two diodes anti-series, one a zener.  Zener points to drain, regular diode points towards gate.  This is a common approach in "protected switch" devices (which are a MOSFET with a controller built in, powered by the "gate" terminal itself).  See diagram here: http://diodes.com/design/support/technical-articles/self-protecting-mosfets-deliver-improved-reliability-in-the-harsh-environment-of-automotive-applications/
I'd still include the S-G zener, to protect against rapid changes, ESD and the like.
Another way is, since we know the load is inductive -- just don't turn it off as fast.  Evidently, it's about 20 times too fast.  If we slow it down 20x, the excess voltage will be manageable.  This is easily done by increasing the pull-down to 2kΩ.
Downside: now the whole turn-off time (Miller plateau), spent with high drain voltage and full drain current, is 20 times longer, too.  Which is 0.5us * 20 = 10us.  If it's dissipating up to 50V * 40A = 200W for 10us, well, that's still well within the safe operating area, we can check that on Fig.11.
So this seems to be a fine option.  Which echoes what some have said earlier in the thread, but this puts a number to it. :-+
-Would the TVS diode and Zener diode fully protect the mosfet/how are they protecting the mosfet? (In my mind something would need to be directly across the coil, ie. GND to 26V not between GND and 12V)
The board is small, at the connector is fine. :-+
The trick here is, the inductor doesn't care where its current is going, it's just a current coming down a wire.  When the transistor turns off, that current just goes into, whatever it goes into.  If nothing's there to catch it, it keeps going into the transistor (as avalanche breakdown).  It's the transistor's fault that the voltage shows up -- it's the causative event.
Aside:
This is actually true to a deep level.  If we do the same thing with faster transistors, we can see the event propagate through space (or at least along wires) at the speed of causality itself, i.e., the speed of light.  A transistor that switches in 1ns for example, goes from off to on in but 30cm at light speed!  You can imagine a spherical shell expanding away from the transistor, encompassing all space that can possibly know about its switching.  Think of the shockwave from an explosive, made visible by the refraction of air; except in this case, instead of pressure, it's the...rather abstract idea of being able to tell an event has happened.  Though conveniently in this case, at least, we can also measure something more concrete, like the change in voltage. :)
I suspect this is just more confusing than useful..... but the point is it's ultimately very fundamental to the universe itself, and the reason your transistor experiences a voltage peak is, in an overly basic but fundamentally true sense, because of causality at the speed of light.  I think that's pretty frikkin cool.
I digress.
So, er, in any case, to close that causal loop, you need something to "cause" current to flow, soon after the transistor stops doing it.  Which means putting the TVS beside the MOSFET, where it can "know about it" immediately.  The inductance can't stop flowing current until it "knows" about it, and it's [this] *waves hands* far away.
Likewise, the clamp diode being at some distance, isn't helping as much as it could be.  Yes, it's clamping the bulk of the solenoid's charge.  Which is, by a huge margin, most of the energy in this system.  But there's still some in the wires stringing everything together.
Because... slimey wimey semiconductor physics? :P
I actually don't know much about this myself.  I guess that's no accident, according to this appnote? https://www.infineon.com/dgdl/Infineon-ApplicationNote_Some_key_facts_about_avalanche-AN-v01_00-EN.pdf?fileId=5546d462584d1d4a0158ba0210977cde
Something about "hot carriers", and I would assume dislocations and other stuff, in a sense causing breakdown of the semiconductor or insulator materials themselves, in a similar way as they would when just utterly blasted (with excess voltage and/or current), but a tiny bit at a time.  Eventually I guess enough defects occur in some point to forms a conductive channel, or it aggravates localized heating or something, and then current draw starts increasing, and pretty soon it shorts out.
Also, this one from ON Semi seems to agree the avalanche curve is single only, https://www.onsemi.com/pub/Collateral/AN-7515.pdf.pdf so it doesn't apply to repetitive avalanche.
(Huh weird, that link is also a .pdf.pdf.  I never noticed that before, I wonder how many of their files are named like that...)
Not quite, avalanche is breakdown.  It seems it's more or less the case that a device can withstand a certain amount of avalanche, total.  So, they're happy to give big fat single-pulse ratings, or even test them in production (as the appnote above says OptiMOS are?), but a few too many of those, or a few too many hundred or thousand or million or whatever of very brief ones, and...not so much.
But yes, if the voltage is kept below breakdown, avalanche does not occur, and operation should be reliable.
So, it does look quite likely that this is the problem, and it would be easy enough to verify with an oscilloscope, if one is handy.  And the symptom should go away with a TVS installed, or any other change that avoids MOSFET breakdown.
TVS diodes do not suffer from the reliability issue, as far as I know.  The problem is that MOSFETs are complicated, they have a bunch of stuff in them that....transists.  Probably, the same wear mechanism occurs in diodes, but the only insulator that could fail, is around the edges of the diode, and stuff getting blasted around there can't really cause problems, partly by careful design I'm sure, and partly because it's just a thin surface around a big fat lump of semiconductor.  (That's another thing that MOSFETs are: surface area.  MOSFETs work purely on a surface effect.  It's all surface, millions of tiny structures etched into the silicon provide enough surface area to handle huge currents.)
Online Circlotron
« Reply #21 on: September 19, 2020, 09:15:36 am »
What are you currently using as a snubber? If you are switching off 40 amps then I'd suggest putting a 1-2uF polypropylene cap directly from source to drain, reasonably close to the mosfet. This will slow things down enough to give the diode a much better chance to catch the voltage despite the stray inductance of wiring etc.
« Last Edit: September 19, 2020, 09:17:33 am by Circlotron »
« Reply #22 on: September 19, 2020, 09:32:02 am »
This post has cleared things up soooo much, seriously Tim you are a life saver, without help I probably would have gone through my whole tub of mosfets without thinking and still not have found a solution. If only this post had existed before i started it would have saved me a whole lot of confusion starting out with mosfets.
Going forward i will probably change the 100ohm resistor to 2k (there is a small resistor pad under the high power one) and definitley include the TVS and zener. (still not 100% on what it's doing but you have more than proven yourself in my mind)
Thanks Again
Antonio
« Reply #23 on: September 19, 2020, 09:36:53 am »
The original snubber was a schottky diode anti-parallel to the solenoid, it failed and blew my mosfet, so I tried again placing 2 in series and it worked even worse than the first time. I still don't know why the diodes didn't work but either way Tim has provided a more than adequate solution.
Offline TimNJ
« Reply #24 on: September 19, 2020, 01:28:24 pm »
Ah just a correction to some of my thoughts above: Your circuit does have series gate resistance, but only at MOSFET shut-off. The 100R "pulls" the charge out of the gate once the BJT is shut off. Not sure why I couldn't see that before, but just to clarify. Your circuit does not really have any gate turn-on control, but that's usually okay, as there's no inductive load current at that point.
I'm not sure if there's a reason to do it differently with a very large inductive load, but I would've went for a totem-pole gate driver (2 transistors, complementary NPN/PNP) so that you don't have to dissipate ~1.5W in the big wirewound resistor while it's on. But, if you're going to bump the resistance up to ~1-2K anyway, then the dissipation is way more reasonable. No need to do anything.
