The vintage method to suppress any spike across a commutating diode from Tx secondary leakage inductance, or a load disturbance, was an RC across each diode and was generically 0.1u and 22R on a pcb and located on the heatsink with the puck/module/stud with shortest practical connection. With 1200V diodes you have some play to use MOV's, but they could degrade if continuous energy into them was above their 'no degradation' limit.
As an aside, some vintage applications like telco rectifiers had to be quite aware of such commutation transients, not only extending into the dc distribution, but also exiting on the AC mains and causing nearby synchronous clocks to go out of sync/time.
