I got myself a Electrophoresis power supply capable of 3kV output voltage, which I want to use as a HV source for experiments as it allows control of voltage, current and power.
The unit has been made by the former Swedish brand Pharmacia in the early 80‘s.
No documentation available so far…
It is working fine but has a feature that is limiting its use: the output requires a minimal load of ca 1mA to activate.
I don’t know whether it’s a kind of safety feature to avoid high voltage on exposed electrodes or just a technical limitation.
The behavior could be fixed by adding a constant current load of 1mA to the output, with only 3W of max. power dissipation.
The voltage range is in principle from 10 to 3000V (I plan to use it above 100V), the circuit would have to cover a huge range.
As MOSFETs are only available to max 1.6kV breakdown voltage, my idea was to make a cascode circuit of four 1kV MOSFETs and a simple current regulator with an OPAMP and a sense resistor.
Unfortunately I don’t have experience with cascode arrangement and wonder if this idea is reasonable.
Can anyone give me advice on HV designs?
