Say I need a 60kV high voltage diode, so I put two 30kV diodes in series, then encapsulate the assembly using epoxy rated for 450v per mil.
Assume the encapsulated assembly is sitting on a ground plane, the cathode end is grounded, and the anode is getting hit with minus 60kV pulses from an ignition coil.
In theory, it should survive with a minimum thickness of 0.133 epoxy (OD of 266 mils, neglecting the diameter of the leads).
What is the minimum thickness of epoxy required at the junction of the two diodes?
The question is, does every point along the string need to be covered with 133 mils of epoxy? Or does the requirement lessen as you go toward the low voltage end?
With the cathode grounded, the junction should never exceed 30kV, so why would it be necessary to protect against 60kV at that point?
