Nice, but there is nothing supporting the front plate, won't it smoosh under use? I'd have put the side panel under the plate, or added flanges.
Quote from: Alex Eisenhut on April 19, 2015, 08:16:13 pmNice, but there is nothing supporting the front plate, won't it smoosh under use? I'd have put the side panel under the plate, or added flanges.That is a good idea, I will probably improve and modify it and add more support to the front. It is solid in it's current form but if it is cut then it will weaken it. Thanks for the nice comments on it.
