The U/V Strip arrived today obviously made from floor scrappings as it had nearly 20 joins in the 5M
Anyway I unrolled it trimmed it to 250mm lengths and squashed it under a few bits of glass on top of my coffee machine to straighten out (about 60 degrees
Spacing I wasn't to worried about but I decided to use most of the roll which gave me 19 strips due to being sent 4.9m
and 20 gaps on the non conductive foil cardboard. 6mm Nuts worked well for 10mm spacers with an occasional check with a ruler.
For wiring I ran positive one side and negative the other and supplied in the middle by some 16AWG wire as the power draw is nearly 2A. Wire links were bent around a carpenters pencil to loop around the oposite polarity pads.
Power to burn at 100%, final wiring and programming to be done over the next few days.
Tracing potential too. This is an inkjet print under a sheet of standard paper.
