Electronic workbench
Time : 6-3-2022 23:27:49
Interpreter version : 6.28.865
Script version : 6.20.1.0.2.42
Filename : Electronics workbench.xml
Simulation values manager
Task "Simulation values manager" was successfully executed (13,5 μs)
Combination target configuration
Target value : 1,234567890 kΩ ± 5 μΩ
Task "Combination target configuration" was successfully executed (61,7 μs)
Combinations configuration
Tolerances : 0,000001%
Granularity : ExtraFine
MaxESerie : E24
Task "Combinations configuration" was successfully executed (83,9 μs)
Component configuration 1 - (A)
Matches specs : NO!
Used E-series : [E24]
Relative difference : 2,8807%
Result : 1,200000000 kΩ ± 12 μΩ
A : 1,200000000 kΩ ± 12 μΩ
Task "Component configuration 1 - (A)" was successfully executed (175,7 μs)
Component configuration 2 - (A~B)
Matches specs : NO!
Used E-series : E012-E024-E024-[E024]-E024-E024-E012-E001
Relative difference : 0,116%
Result : 1,236000000 kΩ ± 12 μΩ
A : 36,0000000 Ω ± 400 nΩ
B : 1,200000000 kΩ ± 12 μΩ
Task "Component configuration 2 - (A~B)" was successfully executed (2,5634 ms)
Component configuration 3 - (A|B)
Matches specs : NO!
Relative difference : 0,11079%
Result : 1,233201581 kΩ ± 12 μΩ
A : 1,300000000 kΩ ± 13 μΩ
B : 24,0000000 kΩ ± 200 μΩ
Task "Component configuration 3 - (A|B)" was successfully executed (2,6918 ms)
Component configuration 4 - (A~B~C)
Matches specs : NO!
Relative difference : 0,0026009%
Result : 1,234600000 kΩ ± 12 μΩ
A : 1,600000000 Ω ± 16 nΩ
B : 33,0000000 Ω ± 300 nΩ
C : 1,200000000 kΩ ± 12 μΩ
Task "Component configuration 4 - (A~B~C)" was successfully executed (122,0467 ms)
Component configuration 5 - (A|B|C)
Matches specs : NO!
Relative difference : 0,00000091%
Result : 1,234567901 kΩ ± 10 μΩ
A : 1,500000000 kΩ ± 15 μΩ
B : 7,50000000 kΩ ± 80 μΩ
C : 100,0000000 kΩ ± 1,0 mΩ
Task "Component configuration 5 - (A|B|C)" was successfully executed (132,1277 ms)
Component configuration 6 - ((A|B)~C)
Matches specs : NO!
Relative difference : 0,00049929%
Result : 1,234561726 kΩ ± 12 μΩ
B : 1,000000000 MΩ ± 10 mΩ
C : 36,0000000 Ω ± 400 nΩ
Task "Component configuration 6 - ((A|B)~C)" was successfully executed (389,6991 ms)
Component configuration 7 - ((A~B)|C)
Matches specs : NO!
Result : 1,234567901 kΩ ± 11 μΩ
A : 150,0000000 Ω ± 1,5 μΩ
B : 1,100000000 kΩ ± 11 μΩ
Task "Component configuration 7 - ((A~B)|C)" was successfully executed (393,0845 ms)
Component configuration 8 - (A~B~C~D)
Matches specs : NO!
Relative difference : 0,00000891%
Result : 1,234568000 kΩ ± 12 μΩ
A : 68,0000000 mΩ ± 0,7 nΩ
B : 1,500000000 Ω ± 15 nΩ
C : 33,0000000 Ω ± 300 nΩ
D : 1,200000000 kΩ ± 12 μΩ
Task "Component configuration 8 - (A~B~C~D)" was successfully executed (4,5768623 s)
Component configuration 9 - (A|B|C|D)
Matches specs : NO!
B : 15,00000000 kΩ ± 150 μΩ
C : 15,00000000 kΩ ± 150 μΩ
D : 100,0000000 kΩ ± 1,0 mΩ
Task "Component configuration 9 - (A|B|C|D)" was successfully executed (4,897420 s)
Component configuration 10 - ((A|B)~C~D)
Matches specs : NO!
Relative difference : 0,0000041151%
Result : 1,234567839 kΩ ± 9 μΩ
A : 390,000000 Ω ± 4 μΩ
B : 1,600000000 kΩ ± 16 μΩ
C : 11,00000000 Ω ± 110 nΩ
D : 910,000000 Ω ± 9 μΩ
Task "Component configuration 10 - ((A|B)~C~D)" was successfully executed (28,590074 s)
Component configuration 11 - ((A~B)|C|D)
Matches specs : NO!
C : 110,0000000 kΩ ± 1,1 mΩ
D : 1,100000000 MΩ ± 11 mΩ
Task "Component configuration 11 - ((A~B)|C|D)" was successfully executed (28,558708 s)
Component configuration 12 - (((A~B)|C)~D)
Matches specs : NO!
Relative difference : 0,0000010791%
Result : 1,234567877 kΩ ± 12 μΩ
A : 4,30000000 kΩ ± 40 μΩ
D : 36,0000000 Ω ± 400 nΩ
Task "Component configuration 12 - (((A~B)|C)~D)" was successfully executed (57,13552 s)
Component configuration 13 - (((A|B)~C)|D)
Matches specs : NO!
Relative difference : 0,00000086778%
Result : 1,234567879 kΩ ± 11 μΩ
B : 1,000000000 GΩ ± 10 Ω
C : 1,100000000 kΩ ± 11 μΩ
Task "Component configuration 13 - (((A|B)~C)|D)" was successfully executed (59,13981 s)
Component configuration 14 - ((A~B~C)|D)
Matches specs : NO!
A : 10,00000000 Ω ± 100 nΩ
B : 240,000000 Ω ± 2 μΩ
C : 1,000000000 kΩ ± 10 μΩ
Task "Component configuration 14 - ((A~B~C)|D)" was successfully executed (19,562633 s)
Component configuration 15 - ((A|B|C)~D)
Matches specs : NO!
Relative difference : 0,0000074071%
Result : 1,234567981 kΩ ± 10 μΩ
A : 1,100000000 kΩ ± 11 μΩ
B : 27,0000000 kΩ ± 300 μΩ
C : 470,000000 kΩ ± 5 mΩ
D : 180,0000000 Ω ± 1,8 μΩ
Task "Component configuration 15 - ((A|B|C)~D)" was successfully executed (19,611336 s)
Component configuration 16 - ((A~B)|(C~D))
Matches specs : NO!
C : 18,00000000 kΩ ± 180 μΩ
D : 82,0000000 kΩ ± 800 μΩ
Task "Component configuration 16 - ((A~B)|(C~D))" was successfully executed (14,648670 s)
Component configuration 17 - ((A|B)~(C|D))
Matches specs : NO!
Relative difference : 0,0000027054%
Result : 1,234567857 kΩ ± 12 μΩ
A : 39,0000000 Ω ± 400 nΩ
B : 18,00000000 kΩ ± 180 μΩ
D : 330,000000 kΩ ± 3 mΩ
Task "Component configuration 17 - ((A|B)~(C|D))" was successfully executed (14,608783 s)
Component configurations
Task "Component configurations" was successfully executed (3,9 μs)
Done
Time : 6-3-2022 23:32:28
