This is my first try at laying out USB 2.0 high-speed traces. I'm using a 2 layer board.
It took me forever to get all the info together. Zdiff = 2 * Zodd and Zsingle = Zeven / 2
With my calculations, I should get 92 ohm diff impedance and 75 ohm single ended impedance.
This is using a 26 mil trace and 6 mil space. The traces are just shy of 12mm long.
The difference between the two traces is 0.03mm.
From all the app notes I read, it is acceptable if the traces change size but only very close to the ends.
How does my layout look?
