Author Topic: How Good Is Faraday Tape?  (Read 493 times)
Offline tdengineerTopic starter
« on: October 25, 2025, 04:56:25 pm »
Does anyone have experience with faraday tape and is it good enough to block the signals in this video down to under 20uv, or .02mv if all exposed metal with signals running through it are covered?
https://www.youtube.com/shorts/a_6VX3qjvsE
Offline bostonman
Re: How Good Is Faraday Tape?
« Reply #1 on: October 26, 2025, 01:04:49 pm »
I think it may help if you provide the device you're trying to build.
The person in the video doesn't know where the noise is coming from after he turns off the device, so a piece of tape may not solve the issue.
You're probably better off using a metal case for whatever it is you're trying to build and not leak RF.
