Edit: My question is how do you measure and improve accuracy of a drill sled/press without access to expensive measuring equipment, or is there a clever diy design for a drill press that makes this simple?
Edit again: added a drawing, below.
Since the solder pot was not economical, it's on to the next impractical diy project!
I'd like to have a very precise drill press/jig, not just to use for pcb drilling but for drilling precise holes in wood, etc.
I've read
this link and it looks like a good idea to use ready made Hiwin clone linear rails.
But how do you align the drill in along 4 axis? First there's the two axis of the "sled" for the Proxxon tool, but the Proxxon also has to be aligned within the sled.
Perhaps one could cobble together a workable solution with a machinist's 1-2-3 block and two high resultion digital cameras to watch how the drill bit moves in three dimesions?
It seems like I'm always reinventing the wheel, poorly, with these sort of things. Do you guys already have a better solution?
