Author Topic: How to install custom Sigrok Pulseview protocol decoder?  (Read 5532 times)
Offline AndySymonsTopic starter
« on: September 22, 2024, 11:51:18 am »
I want to create my own protocol decoder (PD) for a proprietary protocol used by Scantronic 9651 alarm systems to communicate with keypads over a 200m bus.  It is part of a reverse-engineering project to discover and re-use that protocol: https://github.com/AndySymons/KELLY-Scantronic-9940-Keypad
As a first step, I just copied the I2C decoder and changed its name to 'SAKIP' (Scantronic Alarm Keypad Interface Protocol). The Sigrok documentation (https://sigrok.org/wiki/Protocol_decoder_HOWTO and https://sigrok.org/wiki/Protocol_decoder_API) tells me how to create the PD, but not how to link it to PulseView (on MacOS). Simply including the code inside the PulseView 'decoders' directory (inside the .app package), alongside all the other decoders, does not cause it to be recognised.
Can anyone tell me how to get SAKIP to show up in the list of available decoders in Pulseview??
Offline voltsandjolts
Re: How to install custom Sigrok Pulseview protocol decoder?
« Reply #1 on: September 22, 2024, 12:23:00 pm »
No experience of custom decoders, but noticed here:
https://sigrok.org/wiki/Protocol_decoder_API#Decoder_registration
id
A short unique identifier for this protocol decoder. It should be all-lowercase, and only contains a-z, 0-9 and underscores. This must match the PD's Python module name (subdirectory name in the decoders directory). The sigrok-cli tool uses this to specify PDs on the command-line. Examples: 'jtag', 'sdcard_spi', 'uart'.
« Reply #2 on: September 24, 2024, 05:45:27 pm »
Yeah 'registration' is not 'installation' and I do have the API spec (https://sigrok.org/wiki/Protocol_decoder_API).
By trial-and-error I found that on MacOS the procedure is
  • Find pulseview.app in your Applications folder
  • Right click and select 'show package contents'
  • Navigate to /Contents/share/libsigrokdecode/decoders/
  • Either create your own folder here or copy and existing one then change the name
  • Within that folder create or edit the copied files __init__.py and pd.py as described in the HowTo guide (https://sigrok.org/wiki/Protocol_decoder_HOWTO#Files). If you copied an existing protocol to use as a template, you need at least to change its name to a unique one (search for the old name and replace it, preserving the capitalisation).
  • (Re)start the Pulseview app
  • Now if you press press the decoders button, the resulting list should include your new decoder
I Have no idea how to install the PD in any other environment!
It is remiss of Sigrok not to include this information in the HOWTO guide.
The following users thanked this post: voltsandjolts
Online bson
« Reply #3 on: September 24, 2024, 10:53:53 pm »
On Linux (Fedora 40) the default installation (from dnf) is /usr/share/libsigrokdecode/decoders/
They can live there, or in ~/.local/share/libsigrokdecode/decoders.  I just verified the latter works by copying the i2c decoder there and renaming it foo2c. Shows up as expected:
« Last Edit: September 24, 2024, 10:56:31 pm by bson »
Offline nonlinearschool
  • Electrons evade me...
« Reply #4 on: November 04, 2024, 11:11:29 pm »
I hope this is not [/ioff-topic]. However, it is regarding maybe creating a custom multiple devices logging Pulsview, or maybe it is more having multiple Pulsview's screens to run multiple devices from different ports, (or common USB port)?
I have quite a few pieces of test equipment that is compatible with this app. The first example would be running DSLogic as a logic analyzer, and A DMM voltage measurement along side. So I can test multiple components and... Why is it so important is to be able to match times and overlay the final results. Using multiple computers would mean matching exact same clock time of the machine, and even then I do not think it would work.
Do I have create a customized version, or create a custom multiple window setup?
