If you use fast SAR ADCs, then they start conversion typically on a start signal, and not on a command.
Depending on how long your signal is go for a few hundred ksps to a few msps ADC, get upset by it's price, redesign it to not use this method to capture the signal, figure out it doesn't work, buy the ADC anyway, realize it needs to be driven correctly, and so on and so on.
