I want to make several *cheapo* moisture sensors, using stainless steel bolts (AISI 136) connected to the solid copper conductor of a Cat5e cable.
(Let's say this is a given and no other better solution is possible).
What is the best way to connect the cable to the steel bolts?
I can turn it around the bolt shaft and use a nut to keep it in place, but I need a connection that won't allow for the oxidation of copper.
I can try to solder the surface copper, use enamel, hot glue, silicon, on the connection.
The exposed part is the thread of the bolt and it is cemented in a concrete slab.
The entire sensor will be underground, and inaccessible once installed. There won't be any mechanical strain or vibration . The sensors just need to sleep there, undisturbed.
What would you do?
