Author Topic: How to shorten the signal to my doorbell  (Read 361 times)
Offline Sulfur2996Topic starter
« on: April 24, 2024, 05:59:47 pm »
My camera surveillance system NVR has two "alarm" connectors which is a N/O switch. I routed wires from/to my doorbell chime so NVR motion detection can ring my unused rear door chime "dong". The front door chime does a different "ding dong" so I can tell the difference.
It works but the problem is the NVR closes the N/O switch for a hard-coded ~60s and the doorbell chime and 20VAC doorbell transformer is humming the whole time and something's going to blow so I don't use it.
I need to add an inline N/C switch (or something) that opens itself after a short time 0.75 to 1.0s to simulate the release of the doorbell button after a normal human button push delay. Can you give me a tip like "build/buy a self resetting 20VAC N/C thingamajig" to point me in the right direction?
Other people online asking for this get no answer.
I'm mostly a SW guy but tinker with HW too.
Offline tmd63
Re: How to shorten the signal to my doorbell
« Reply #1 on: April 24, 2024, 06:03:34 pm »
Probably want a pulse shortener using a 555 timer.
check falstad circuit simulator java, I believe has has 555 timer circuits there.
Or check this out
https://www.edaboard.com/threads/pulse-shortening-circuit.297254/
The following users thanked this post: Sulfur2996
Offline ajb
« Reply #2 on: April 24, 2024, 06:14:43 pm »
There's an easy off-the-shelf solution: a timer relay.  These are standard automation components, and can often be configured for multiple operating modes with a wide timing range.  The mode you'd want is usually called "one shot".
There are cheaper options than these, but AutomationDirect has a lot of options with very good documentation (not sure if they ship to Canada): https://www.automationdirect.com/adc/shopping/catalog/relays_-z-_timers/timer_relays
These instructions in particular have a nice description of the various configurations, but many/most multifunction timer relays will have similar options: https://cdn.automationdirect.com/static/manuals/fujitimersm/trm10installation.pdf
« Reply #3 on: April 24, 2024, 06:58:06 pm »
I'll try the off the shelf configurable timer relay idea. Had no idea these things existed. Thanks!  :-+
Online NiHaoMike
    • Facebook Page
« Reply #4 on: April 25, 2024, 12:58:21 pm »
A simple solution would be a series PTC. Measure the current and select a PTC with a substantially lower trip current and a much higher voltage rating than your circuit voltage. (Repeated operation of the PTC near its voltage rating causes it to degrade.)
Offline PCB.Wiz
« Reply #5 on: April 25, 2024, 09:22:18 pm »
If you are ok with a PCB module, there are shiploads of what look like cloned timer relay variants from Aliexpress.
Some use Nuvoton N76E003 MCUs so you could completely reconfigure if you wanted to, but the default of trigger -> time relay pulse sounds like what you wanted anyway.
LED models
https://www.aliexpress.com/item/1005006151283961.html
and more recent are LCD models
https://www.aliexpress.com/i/1005004189362865.html
or, you could experiment with a simple series cap / resistors that give a short decaying pulse on the leading edge.
If it is a NO relay drive, a parallel drain resistor across the Cap discharges it.
Needs to be large enough to not trigger the bell by itself, but low enough to give a reasonable retrigger time, tho your fixed 60s may limit that anyway.
« Last Edit: April 25, 2024, 09:27:21 pm by PCB.Wiz »
