Author Topic: Howard Johnson notes on SI and scopes  (Read 3756 times)
Offline AlfBazTopic starter
« on: February 16, 2014, 01:41:52 am »
Just found these 8 short notes by Dr Howard Johnson for lecroy.
This may have been posted already but I couldn't find it with a quick search
http://teledynelecroy.com/support/techlib/signalintegrityfundamentals.aspx?capid=106&mid=528&smid=661
The 8 articles
If you've never registered on our site, you'll be redirected to a short form to fill out before viewing the papers.
   Step Response Test  - Using The Step Response To Analyze A Signal Channel
   Confirm Diagnosis - Using The Step Response Along With The Circuit Layout To Isolate And Fix Signal Reflections
   Adequate Bandwidth - How Much Oscilloscope Bandwidth Is Required To Measure My Signal Accurately?
   DC Loading  - Verifying The Affect Of Probe DC Loading On Measurements
   Why Is That?  - Exploring A Signal Waveshape To Uncover Sources Of Distortions Caused By Loading
   Jitter Characterization - Explaining the fundamentals of jitter and jitter measurements
   Jitter Creation - If you are just learning to make jitter measurements, begin with a calibrated source of jittery data.
   Jitter Capture - The practical measurement of jitter
As you can see it requires registration ::)
I could zip them and attach (about 2M) just not sure on the ethics
Offline oohal
Re: Howard Johnson notes on SI and scopes
« Reply #1 on: February 16, 2014, 06:21:03 am »
Looks like you can get all of these off Johnson's website. Incidently bugmenot is pretty rad for getting around registration walls.
Offline zapta
« Reply #2 on: February 16, 2014, 06:33:05 am »
Mailinator.com is your friend ;-)
Offline codeboy2k
« Reply #3 on: February 16, 2014, 12:03:40 pm »
10minutemail.com  :-+
Offline zapta
« Reply #4 on: February 17, 2014, 12:56:14 am »
Offline dannyf
« Reply #5 on: February 17, 2014, 01:24:27 am »
Wow. That Howard Johnson guy is not only good at building cheap motels, but also equally good at electronics.
« Reply #6 on: February 17, 2014, 01:55:55 am »
Nice, thanks
